Lug nuts.
Discussion in 'Questions From New Drivers' started by larry_minn, May 18, 2025 at 10:58 PM.
  1. larry_minn
    larry_minn Light Load Member
    181
    131
    Nov 15, 2012
    Minnesota.
    Some downtime. Have a slow leak, figured pull tire. A 1 5/16 fits good. Told it’s a 33mm. I bent breaking bar with a pipe to point I thought it might break the bar. I sprayed penetrating fluid 3 days ago, had rain, wind so got to it today.
    I have a Dewalt 1/2” impact. Iirc over 1000 ft/lbs tightening, even more loosening are claimed.
    So going to get 1 5/16 or 33 mm deep well impact socket. Is it better to go metric? It’s like .013”different.
    Is the Dewalt 20v 1/2” enough?
    Or just hope breaking bar holds? I have broke them before.
    On side note. Saw a step deck load. Pipe, full length. Started upper deck, load leveler on back. Straps over in middle. Unsupported pipe, 2 layers, no belly wrap. I don’t think any belly wrap ebven on front deck.
    Shouldn’t there be one more load leveler? No idea how much the pipe flex at +35’ unsupported? WAG.
    Or unhook, drive it to tire shop after airing up last 40 psi after 2 weeks?
  3. sirjeff
    sirjeff Medium Load Member
    436
    1,253
    Dec 1, 2013
    Kootenays, British Columbia
    I bought my Dewalt 1/2 to do my truck tires and was disappointed. Took 1 5ah battery to get 7/10 loose. 1440 breaking torque? My arse
    Need the big 1" electric Milwaukee, or a proper 1" air impact off a 1/2" line. Truck compressor will run the big impact in a pinch but not well enough, imo
    77fib77, ducnut and 201 Thank this.
  4. LOTSO
    LOTSO Heavy Load Member
    739
    1,769
    Mar 28, 2023
    Does anyone know what this man said???:dontknow:
    Walk Among Us, Rugerfan, Opus and 3 others Thank this.
  5. D.Tibbitt
    142,779
    I have Milwaukee half inch can do all the drives on 1 battery. If I remember I use the standard socket and it worked fine.. since I don't have that size in metric.. I'd imagine trying to get lug nuts loose with just a bar you would have to be strong as a Silverback gorilla
    77fib77, Long FLD and AModelCat Thank this.
  6. AModelCat
    155,632
    Or as strong as 100 men.
  7. Iamoverit
    Iamoverit Road Train Member
    1,748
    3,857
    Oct 31, 2023
    You'll need to put some heat on them. Propane might do it. If not the big red hammer will get 'em loose. You could also take them to a nearby shop and have them bust them loose and put them back on no tighter than 500ftlbs.
    Nut should be 33mm but it depends on their condition as to how well it fits and/or what other sizes might fit. When you reinstall them yourself put a couple drops of oil on the studs first. That will help prevent corrosion from locking them next time.
    D.Tibbitt, Long FLD and 201 Thank this.
  8. Sons Hero
    Sons Hero Road Train Member
    1,981
    19,415
    Jan 8, 2021
    Indiana
    1” Milwaukee for the win!!! My 1/2” has worked in the past, but the 1” is much faster. Milwaukee has much more torque than Dewalt, and I know that for a fact, because me, and 2 of my other brothers have Milwaukee, one brother has Dewalt. There have been many shop contests over the years, but Dewalt never wins. Go figure
  9. Big Road Skateboard
    5,812
    30,705
    May 2, 2021
    1-5/16" will work fine, bit that Dewalt ain't gonna. Yeah, ratings on some impacts are skewed.
    They torque to 500ish, but very few actually torque them, and most are over 600 ft lbs.
    A long 3/4 or 1" ratchet, 12" extension, and socket will do it. Long = 4' plus
  10. ducnut
    ducnut Road Train Member
    2,501
    7,507
    Dec 31, 2010
    SPI
    DeWalt is crap. A 3/8” Milwaukee will easily outperform a 1/2” DeWalt, which won’t even budge car lug nuts torqued to 120ft/lbs.
    Sons Hero Thanks this.
  11. 201
    201 Road Train Member
    12,128
    24,747
    Apr 16, 2014
    high plains colorado
    I agree, get the nut hot, not the stud, and 1" drive impact is about the best bet. A breaker bar won't do it, the bar itself isn't strong enough, and even though we've all done it, put a longer pipe on the handle, it's not recommended. Years ago, wheels came off so often, the nuts never seized, but today, they can be on there for years. 1" drive, even the road crews use 1" drive.
    ducnut, Sons Hero and Iamoverit Thank this.
