lunch box cooker
Discussion in 'Food & Cooking in the Truck | Trucker Recipe Forum' started by Brucesmith, Aug 24, 2012.
  1. Brucesmith
    Brucesmith Heavy Load Member
    733
    502
    Jun 16, 2012
    I am starting at a new company and the truck does not have an inverter. After I have been there for awhile I will install one. In the meantime I would like to be able to heat some canned food . How do you heat cans in the lunch box cooker without pouring the contents into the foil pans? Can you punch a few holes in the can? If you do what keeps the contents from spilling? Do the truck stops have a bird if you use their microwave to heat your own pakages of food?
    Thanks
  3. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    first off dont buy the foils pans at the truck stop, go to a family dollar, dollar general or fred's they are 3 for 1.00 there. and if the can is short enough to fit in the lunchbox a few holes will do the trick. but using the pans will be the best way. if ya think the pans are expensive, eat in the truckstop, lol.
  4. mc1910
    mc1910 Bobtail Member
    4
    Do the truck stops have a bird if you use their microwave to heat your own packages of food?
    I always ask 1st and have never been told NO
  5. Killer60148
    Killer60148 Light Load Member
    Its the only thing ive gotten from pilot that is still working. Skateboardman is right. Buy the tin trays at any dollar store or walmart.
  6. geargrinder
    geargrinder Medium Load Member
    325
    69
    Nov 23, 2006
    More than likely waiting.
    I buy a roll of aluminum foil and just mush it around to the general shape of the cooker. Lunchbox cookers are awesome. I am a veritable lunchbox gourment lol.
  7. apyles
    apyles Medium Load Member
    449
    142
    Oct 21, 2011
    Newbern,Tn
    let's hear some of your secret recipes .
  8. djchaos76
    djchaos76 Bobtail Member
    38
    7
    Feb 1, 2010
    Rushville, IL
    I just peel the labels off the cans and stick them laying down in the cooker. When they're warmed up, I just eat it out of the can. I also line the bottom with foil and cook Hot Pockets, pizza rolls, ect.
  9. Brucesmith
    733
    502
    Jun 16, 2012
    Thanks for all the info.
  10. ghettochild
    ghettochild Medium Load Member
    336
    76
    Jan 13, 2012
    atlanta,ga
    Can foods contains a lot of sodium..be careful if u have high bp
  11. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Like the other poster said, most truck stops have microwaves in which you can use. You can also buy a very cheap, small plug in inverter that will work just fine for most of your electronics and small appliances. Probably the only thing it won't run is a refrigerator. You can get one at Walmart, Radio Shack, or if you are rich you can pick one up at a truck stop! Besides the little lunch box cookers you can also buy a small toaster over or even a little crock pot works really well! Some of these appliances you can buy with the cig. lighter cord already attached.
    Personally I just got used to eating everything cold. It never really bothered me. I would eat lots of healthy soups, canned vegetables, beans, etc... I would also put a few packs of oatmeal in a solo cup and add some room temp bottled water and had a healthy breakfast! Solo cups help keep from doing dishes! Also would take a can of chicken or tuna and dump it in a freezer bag add some mayo and spices then zip it up and squish it all around until it was mixed. This also saved on dishes and was healthy too!
    There are many little tricks you will learn or invent that will help you with your day to day chores out there that will make life simpler.
