m11 cummings idle shutdown
Discussion in 'Trucks [ Eighteen Wheelers ]' started by steven10918, Mar 27, 2011.
  1. steven10918
    steven10918 Bobtail Member
    does anybody know how to get rid of the idle shutdown on a 2000 m11 cummings?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    do you want to disable idle shutdown? if it is Volvo, you need VCADs pro ore PTT. becouse when I did it with Insite software, VECU kept shutting down engine
  4. DumpTrucker
    DumpTrucker Bobtail Member
    30
    Sep 3, 2007
    Joplin MO
    I went to Cummins and has them disable it.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    some Volvo '98 verion VECUs may shut engine down with J1939 CAN, so I'm not sure
  6. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    That is controlled by the ECM, so cummins or someone with the program needs to hook up to your ECM to change the setting, Cummins offered to do mine for free if I took the truck to them.
  7. steven10918
    weve had the truck to volvo and midatlantic cummings 3 times, it cost $75 to reprogram it and it still shuts off unless you sit there and it the brakes
  8. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    The ECM may be password protected, and so they couldn't make the changes, but they should have told you that. If it is not password protected, take it back!!! You paid for the changes and they missed it or did something wrong!
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Password protection is not a problem for good technician
  10. Big_Red_Machine
    Big_Red_Machine Bobtail Member
    11
    Feb 10, 2011
    Open road
    Does this truck have an ICON system on it? If so that may be also shutting you down. If not have them go in and disable each parameter under idle shutdown. Ambient temp, PTO, and set time before shutdown up to 60 minutes. Then go in and disable the header parameter. Make sure they are sending this to the ECM also, you can change them in insite, but if its not sent to the ecm it wont save.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what ICON system on so old truck? it is not ISM11 it is Celect M11, ore Celect plus.
    There were Road Relays used, but.. seems to me everething is not so complex as you think. Just one parameter easy to change with Insite. Yeah, Volvo VECU may shut engine down too, but I do not think they programmed it this way, anyway easy to change with VCADs Pro (VTT/PTT)
