m11 flash codes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hard times, Feb 18, 2011.
  1. hard times
    hard times Bobtail Member
    49
    Feb 13, 2011
    lafayette la.
    can any one tell me how to do the flash codes on a 98 volvo m11?
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    cant help with that but here is the list of codes.
    CUMMMINS SELECT CODES
    111 Electronic Control Module (ECM Microprocessor
    115 Engine Position Sensor (EPS Circuit
    121 Engine Position Sensor Circuit (EPS
    122 Intake Manifold Pressure Sensor Circuit
    123 Intake Manifold Pressure Sensor Circuit
    131 Accelerator Position Sensor Choice
    131iss Accelerator Position Sensor Circuit
    131ivs Accelerator Position Sensor Circuit
    131sss Accelerator Position Sensor Circuit
    132 Accelerator Position Sensor Choice
    132iss Accelerator Position Sensor Circuit
    132ivs Accelerator Position Sensor Circuit
    132sss Accelerator Position Sensor Circuit
    135 Oil Pressure Sensor Circuit
    141 Oil Pressure Sensor Circuit
    143 Oil Pressure - Engine Protection
    144 Coolant Temperature Sensor Circuit
    145 Coolant Temperature Sensor Circuit
    151 Coolant Temperature - Engine Protection
    153 Intake Manifold Temperature Sensor Circuit
    154 Intake Manifold Temperature Sensor Circuit
    155 Intake Manifold Temperature Sensor - Engine Protection
    212 Oil Temperature Sensor Circuit
    213 Oil Temperature Sensor Circuit
    214 Oil Temperature - Engine Protection
    221 Ambient Air Pressure Sensor Circuit
    222 Ambient Air Pressure Sensor Circuit
    234 Engine Overspeed
    235 Engine Coolant Level - Engine Protection
    241 Vehicle Speed Sensor Circuit
    241auto Vehicle Speed Sensor Circuit
    241ind Vehicle Speed Sensor Circuit
    242 Vehicle Speed Sensor (VSS Circuit
    243 Engine Brake Supply Circuit
    245 Engine Fan Clutch Supply Circuit
    249 Ambient Air Temperature Sensor Circuit
    254 Fuel Shutoff Solenoid Supply Circuit
    255 Fuel Shutoff, Fan Clutch, Engine Brake Supply Circuit
    256 Ambient Air Temperature Sensor Circuit
    267 Ambient Air Temperature Signal Incorrect
    269 Vehicle Anti-Theft Protection Activated
    289 Vehicle Accessory Shutdown Driver - Not Identifiable
    311 Injector Choice
    311n14 Injector Circuit
    311m11 Injector Circuit
    312 Injector Choice
    312n14 Injector Circuit
    312m11 Injector Circuit
    313 Injector Choice
    313n14 Injector Circuit
    313m11 Injector Circuit
    314 Injector Choice
    314n14 Injector Circuit
    314m11 Injector Circuit
    315 Injector Choice
    315n14 Injector Circuit
    315m11 Injector Circuit
    321 Injector Choice
    321n14 Injector Circuit
    321m11 Injector Circuit
    322 Injector Choice
    322n14 Injector Circuit
    322m11 Injector Circuit
    323 Injector Choice
    323n14 Injector Circuit
    323m11 Injector Circuit
    324 Injector Choice
    324n14 Injector Circuit
    324m11 Injector Circuit
    325 Injector Choice
    325n14 Injector Circuit
    325m11 Injector Circuit
    331 Injector Choice
    331n14 Injector Circuit
    331m11 Injector Circuit
    332 Injector Choice
    332n14 Injector Circuit
    332m11 Injector Circuit
    343 Fault Processing Computer (FPC Chip
    352 Sensor Supply Circuit
    415 Oil Pressure - Engine Protection
    422 Coolant Level Sensor Circuit
    431 Idle Validation Switch Choice
    431iss Idle Validation Switch Circuit
    431ivs Idle Validation Switch Circuit
    431sss Idle Validation Switch Circuit
    432 Accelerator Pedal Circuit Choice
    432iss Accelerator Pedal Circuit
    432ivs Accelerator Pedal Circuit
    432sss Accelerator Pedal Circuit
    433 Intake Manifold Pressure Sensor Circuit
    434 Unswitched Battery Supply Circuit
    441 Unswitched Battery Supply Circuit
    442 Unswitched Battery Supply Circuit
    474 Starter Solenoid Lockout Relay Driver Circuit
    536 Autoshift Low Gear Actuator (Lockout Solenoid
    537 Autoshift High Gear Actuator (Shift Solenoid
    544 Top2 Transmission Circuit - Mechanical System Failure
    551 Idle Validation Switch Choice
    551iss Idle Validation Switch Circuit
    551ivs Idle Validation Switch Circuit
    551sss Idle Validation Switch Circuit
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    111 code usually means that ECM require repare) I like this code!
