Mack Anthem drivers help clear a notification that is annoying me
Discussion in 'Questions From New Drivers' started by Suspect Zero, Dec 28, 2018.
  1. Suspect Zero
    Suspect Zero Road Train Member
    2,508
    9,530
    Oct 10, 2016
    Burbank, IL
    The answer to this has to be in the owners manual somewhere but I've looked thru it multiple times and have yet to find it, nor have I been able to find a setting for it in the set up menu.
    There is a pop up notification that will appear when outside temp gets down to a certain point that informs you of temp and possible freezing/icing conditions. I can clear it easy enough but a few minutes later it comes back again.
    Can someone please tell me how to disable this #### thing? It's a distracting pain in the ###, and contrary to popular belief, I am smart enough to figure out when the temps are in that range on my own.
    stillwurkin Thanks this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,673
    18,444
    Nov 1, 2010
    Burnsville, MN
    It possibly might only be able to be changed through the ECM in the shop.
    Suspect Zero Thanks this.
  4. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
  5. Suspect Zero
    2,508
    9,530
    Oct 10, 2016
    Burbank, IL
    I was afraid it could be something like that. Thanks guys.
  6. Mike2633
    Mike2633 Road Train Member
    6,461
    25,989
    Jun 14, 2013
    At Home on The West Side
    Our Volvo's have the same thing you can hit the escape key on the control stick, but usually it likes to come up and stick around.
    Suspect Zero and homeskillet Thank this.
  7. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    I'm guessing just about every vehicle has a warning these days.
    I drove a 12 and 16 FL that was annoying. My 07w9 I"m in now has the frost light on the temp portion of the dash. 34 seems to be the alarm warning.
    I have a 17 chevrolet that also displays the message at anything 34 and under. But at least it goes away.
  8. Suspect Zero
    2,508
    9,530
    Oct 10, 2016
    Burbank, IL
    Yes, seems like they all do. The T680 I was in at my last place had it also, but it was not as intrusive as this one is. I can clear it like with @Mike2633 s Volvos, it just irritates me. This thing will literally pop up every 5 minutes when the temp gets down to the trigger point, which seems to be 35 degrees.
    Oh well, when it goes in the shop for PM I'll ask if they can/will do something with it.
    Mike2633 Thanks this.
  9. Truckermania
    Truckermania Road Train Member
    1,166
    1,754
    Oct 13, 2011
    Sturgis,SD
    My Volvo does the same thing. Mack is owned by Volvo so probably is identical. I don't know of a way to disable it.
    Mike2633 and Suspect Zero Thank this.
  10. snowwy
    20,553
    13,281
    Jul 6, 2009
    I asked the dealer if they could do anything when the FL I was driving was getting serviced.
    NOPE was the answer I got.
  11. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    a strategic boogger can be wiped on that, keep building them up on that warning light.
