Mack LE600 garbage truck What is this warning light?
Discussion in 'Questions From New Drivers' started by FallGuy44, Sep 6, 2018.
  1. FallGuy44
    FallGuy44 Bobtail Member
    40
    45
    Sep 1, 2015
    Not new really but don't know where to ask this. I'm in a Mack LE600 garbage truck. The warning light is a red circular arrow starting at 7 o'clock with the arrow going clockwise stopping at 5 o'clock. There is a big red X going through it. Also getting a warning alarm beeping. Thanks all.
  3. Omega7777
    Omega7777 Medium Load Member
    392
    414
    May 21, 2018
    pack your stuff and jump out, it is going to explode soon !
    Opus, Fuelinmyveins and Oldironfan Thank this.
  4. FallGuy44
    40
    45
    Sep 1, 2015
    Ha! I was thinking it was the abandone ship light. We are using on a TV show today so thankfully I'm not in it all day having to listen to it.
  5. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    That means your job is NOT a 7am to 5pm job, you are on call 24/7/365.
  6. Ridgeline
    22,400
    116,424
    What you saw was a #### down indicator telling you that the engine will shut down within 15 or 20 seconds.
  7. Omega7777
    392
    414
    May 21, 2018
    "That is the engine shutdown indicator. It should only come on for low oil pressure, high coolant temperature, low coolant level, high transmission temperature, and high pyrometer. If everything was ok then you may have an electrical problem"
  8. plankton
    plankton Medium Load Member
    456
    624
    Jan 9, 2015
    We’re you idling for a long time? Did it shut down?
    There might be an override button on your dash that will prevent engine from shutting down when that happens...
  9. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Affirmed. This is an indicator that the self-destruct sequence is running.
    buddyd157 Thanks this.
  10. FallGuy44
    40
    45
    Sep 1, 2015
    No, not idling at all. They drove the truck to location with it on and I drove it on set with on, with no issues. I had never seen that before and googling didn't help. Thanks all for the help. Thankfully, not my truck and if it breaks down, I'm not stranded!
  11. shatteredsquare
    shatteredsquare Road Train Member
    1,403
    1,832
    May 23, 2014
    middle dirt
