Mack MP7 Injector cups
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kirbyhash, Jun 17, 2020.
  1. Kirbyhash
    Kirbyhash Bobtail Member
    Jun 17, 2020
    Has anyone had a problem getting the correct cups for the MP7? As you can see from the pic's, the injector does not seat in the new cup correctly. according to the model/serial number they are supposed to be the correct cups for this engine?
    truckdriver31 Thanks this.
  3. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    the injector does not sit in the cup being that the cup has to be properly installed in the head so the tip will get pressed out once installed than it will sit properly, whoever is doing this for you they are not anywhere near qualified to do this job if you are doing it yourself you have to be very carefull this is the right cup tip is smalled now when installed it will be the same.
    truckdriver31 and Doealex Thank this.
