mack mp7 vs mp8-reliability
Discussion in 'Mack Forum' started by digteam6, Apr 6, 2014.
  1. digteam6
    digteam6 Bobtail Member
    12
    Mar 5, 2014
    I have been wondering which engine would be more reliable/durable.I have heard people were having problems with the mp7,is this true. And witch one if spec'd the same would have more power.
    Thanks.
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    MP8 is better so yes 7 has some problems. I looked at a MP7 in a 2011 that was blown up at 256k cause the valves were adjusted wrong and it ate a valve. 10k to reman plus a head so 15k all done at Mack assuming nothing else was bad. Guy wanted 22k for truck as it was.....I passed based on a recommendation from Mack.
    Take the last 6 of the vin to Mack and run the service records...they will tell you.
    Good luck
  4. bigchuckie
    bigchuckie Light Load Member
    82
    13
    Oct 3, 2007
    Middle of nowhere maine
    Cant say anything about an MP8. I have driven a Pinnacle with an MP7 for app 200k. Only issue I have had is the fan fell off going 75 mph. I was expecting a a huge hole in the radiator, Nope fan disintegrated in the shroud.The bolts holding the fan on were not heavy enough to support the fan. On a normal road it may be ok. This happened in Northern Maine on I 95 where they have forgotten what asphalt is used for
    SHC Thanks this.
