made a mistake
Discussion in 'Questions From New Drivers' started by Mrh2008, Jan 3, 2013.
  1. Mrh2008
    Mrh2008 Road Train Member
    1,288
    310
    May 25, 2012
    Mesa, AZ
    Could have ended pretty bad. I was coming down the hill to Denver on 70 last night, headed from vegas. Cold and wet with some ocasional ice in spots. 78k gross, coming down the hill to the weigh station, jake off... started cookin the brakes. Couldnt slow down enough to grab another gear, and couldnt trust the road to throw my jake on. Tried to ride it out, but that wasnt workin so good! I grabbed the next gear up and let it go for a few, hoping that they'd cool off enough to slow me down. hopped on the brakes again and watched as the smoke started billowing out! Finnaly got her to drop another gear and threw the jake on. I honestly thought I was gunna see fire.
    That wont happen again!
    What is the best thing to do if you find yourself in this situation? I took my chances with the jake, id rather jack-knife at 40 than go off the side at 90.
    Also, I know what I did wrong that got me into that situation, but is there anything i could have done to get me out?
  3. socal
    socal Medium Load Member
    574
    348
    Feb 18, 2008
    Los Angeles CA
    Use the #### jake unless it is a absolute ice skating rink you can easily get by using it on 2 or 4 cylinder setting. Also if the road is wet find some of that water or slop and run through it to cool the brakes.
    rockee and TRKRSHONEY Thank this.
  4. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Get into a lower gear before you start going downhill. Don't pay attention to the truckers behind you. You can go too slowly down a mountain thousands of times. You can go too fast once..
  5. Mrh2008
    1,288
    310
    May 25, 2012
    Mesa, AZ
    I figured that out! I was always told not to use the jake when its wet... ever. I have thrown it on while it was raining to see what I could get away with, but last night, it was wet with a few areas of snow and I was looking at 3 degrees on my thermometer. Didnt think it was a good time to test it out.
  6. Batoexpress
    Batoexpress Bobtail Member
    31
    9
    Aug 12, 2012
    Wisconsin
    On a side note, and I may be showing my age and ignorance on this...are the brakes compromised after smoking them???? In the old days, they would "crystallized"...I changed many shoes on POS Fords, Chevrolets in the 80's
  7. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    use the jakes always. if you hit an icy spot the rpms will drop. but than again if your on your brake its going to do the same thing. get the point. jakes or no jakes if you hit ice using either you will know it atleast with the jakes you have help to keep it slowed down
    TRKRSHONEY Thanks this.
  8. Chinatown
    Chinatown Road Train Member
    74,828
    170,567
    Aug 28, 2011
    Henderson, NV & Orient
    Sometimes, put the wheels on the right side of the truck, just off the main pavemet onto the shoulder where the slush or rougher pavement is. This depends, of course, on the conditions.
    NavigatorWife Thanks this.
  9. Moosetek13
    Moosetek13 Road Train Member
    14,673
    18,442
    Nov 1, 2010
    Burnsville, MN
    Ice is less slick at 3 degrees than it is at 28 degrees.
    In general, the colder it is, the better traction you will have.
    I almost always use my engine brake, to some degree.
    At 78k I would have quickly found a gear that allowed me to hold a safe speed using a medium setting on the engine brake combined with very light service brakes every 5-10 seconds.
    That might mean 35 MPH speeds from the top down.
    If other trucks want to go faster than you are prepared to go, let them either go around you or follow you.
    You set your own pace.
  10. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Jakes (engine brakes) alone will never cause a jack knife. If the trailer starts to show signs of coming out of line (coming around), slight throttle will return the units to a straight line. With that said, the issue of ice/wet roads and jake application is an issue of "breaking traction", in this case, "skidding"...this is a result of excessive application of brakes, either with or without the use of jakes.
    This is a good...nay, excellent example of how experience teaches drivers! Having the knowledge that the conditions are less than favorable (wet/icy), heavy load, and long and steep down grade...begin the down grade slower and in a lower gear with jakes at the high setting, try dropping the jake to the middle setting in the same gear...if the rpm's climb up, return jake to high...next try going up a gear with the jakes still on high. Find the combination that will maintain a comfortable speed/rpm with minimal use of brakes. Remember, short, slight brake application is best....why work yourself, let the equipment do the work.
    EZX1100, AZS, Moosetek13 and 2 others Thank this.
  11. socal
    574
    348
    Feb 18, 2008
    Los Angeles CA
    Really you should try descending some hills with no Jake usage at all. It will be a good learning experience. Not all trucks used to have engine brakes. I was driving west coast with no engine brake up until 2007. Learn how to do it right and then the jake will make it a piece of cake.
    I am sure there are some drivers that would refuse to run without a jake these days.
    Also just because the truck breaks traction does not equal instant jacknife.
    aiwiron, Speedemon1084 and otherhalftw Thank this.
