Major problem!! Need help!!
Discussion in 'Ask An Owner Operator' started by Batman13, Sep 22, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    Alright so when driving..whenever I hit a bump wether small or big...all the dash lights come on with that eerie sound...just like when the truck is off and your turning it on...and my gauges go from 0 all the way to the other side..and it's like the truck slows down..almost like it wants to shut off..I have yo take it out of gear and wait til it let's me put it back in gear...now it seems like even the super tiny bumps it does this!! I have a freightliner cascadia 2014...anyone have any ideas??!
  3. Dave_in_AZ
    418,501
    Loose connection.
    Pop the 4 screws out of the instrument panel and see if the connector is loose at the wiring harness where it plugs into the instruments.
    It's just one harness. Your instrument panel is just a circuit board.
    Sirscrapntruckalot and Batman13 Thank this.
  4. Milr72
    Milr72 Medium Load Member
    578
    1,419
    Dec 16, 2011
    S W Missouri
    Sounds like a bad ground connection at the battery or frame.
    DUNE-T and Batman13 Thank this.
  5. Ridgeline
    22,675
    121,475
    I second this, take it to the dealer and have them go through all the connections.
    Batman13 Thanks this.
  6. Powder Joints
    7,960
    8,320
    Sep 25, 2007
    Rosamond, SoCal
    Check your grounds, start at the Battery then to the frame and engine connections, look for possible shorting while your there.
  7. abyliks
    abyliks Road Train Member
    4,056
    9,542
    May 2, 2010
    ludlow MA
    Dealer will rape you, time to get dirty, there are other grounds on the cab as well
  8. Batman13
    110
    45
    May 20, 2020
    Thanks for all the info..it turns out it was a loose ground...I guess all these ###### up roads just loosened em up...it took an hour or so taking things apart but luckily we got it going..and so far smooth sailing..thanks!!
  9. Powder Joints
    7,960
    8,320
    Sep 25, 2007
    Rosamond, SoCal
    No, they were not tightened up properly to start with. Driving does not loosen the connection if it was properly secured to start with. S.... happens stay safe.
  10. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Since the lights were blinking, I was going to suggest checking the blinker fluid level.
    Milr72 Thanks this.
  11. Milr72
    578
    1,419
    Dec 16, 2011
    S W Missouri
    A driver is not allowed to do that. It has to be done by a certified tech!
    SteveScott and rachi Thank this.
