http://www.youtube.com/watch?v=w_hWIySz3KY
i had them slide on me one time a few years back, thought a bomb went off
this gent wasnt so lucky
Make sure your tandems are LOCKED!!!
Discussion in 'Experienced Truckers' Advice' started by EZX1100, May 10, 2013.
We recently had a Port driver pulling a twenty foot container on a goose neck tri-axle frame. Needless to say he forgot to check the slider pins (only two on those set ups). We now have a loaded container on a frame on the ground and the tri-axle set up is across the yard. It happened not far from the yard. Never did like pulling those units.
There's no excuse for not checking the tandem pins after you've hooked to a trailer. They should be checked EVERY TIME.
A lot of the YouTube comments say it was cause he hit the guard rail ... Even if he hit the guard rail with the pins locked he wouldn't had flown off like that would he??
Nailing the guard rail may also push in the pins on that side, while at the same time putting a lot of backward force on the tandems (think wheels rubbing against the guard rail). I don't think this had anything to do with not making sure the tandems were locked, this more likely had something to do with distraction or fatigue. Whenever you are in a construction zone the lanes can be very narrow and you really need to be on top of your situation at all times, it is not a good time to be talking on the phone, eating, drinking, or changing radio stations...
... for that matter it isn't a good time to be yakking on the CB either... -
Never forget this...happened probably in 1997.
I was leaving with a load out of Budweiser in Williamsburg, VA. As I'm pulling to the guard shack, I notice flashing lights on the exit lane leading to the road. Driver forgot to lock his tandems, and his had not only slid out from underneath the trailer, they were up against the doors! Up in the air! Wildest thing I had ever seen. -
Pre-tripping a trailer is just as important as the tractor, and needs to be done each time you hook up. If you get into a routine for checking over a wagon, it will prevent incidents like the above from occurring. As to the video, it can't be determined if the guardrail contact caused the pins to let go, but there are numerous incidents of what happens what the pins aren't checked before departure, and that can cause real problems. Don't forget.
Let me add make sure your fifthwheel pin is locked also,lol.
CHICKENMAN Thanks this. -
