making turns, whats your technique?
Discussion in 'Experienced Truckers' Advice' started by dirtjersey, Oct 15, 2012.
  1. dirtjersey
    dirtjersey Light Load Member
    Ive been driving for 15 months. 8 otr & 9 local. Im ok but still im new. So when i turn around cprners here in jersey. I dont have too much a problem being in day cab and all. But i would love to know how others do it to get a good precise turns. How do you observe the landscape before you make your turns? How do you know how wide to turn when turning corners?
  3. lonewolf21
    lonewolf21 Bobtail Member
    22
    11
    Apr 14, 2012
    Kenora, Ontario
    When you are going to make your turn, when you think you have given yourself enough room, swing a little wider)!
  4. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    This is probably the best advice as its what I follow also. :biggrin_255:
    dirtjersey Thanks this.
  5. snowman01
    snowman01 Road Train Member
    1,246
    713
    Sep 27, 2011
    North Carolina
    I use all of the room that I have. I've never taken a turn too wide that I can remember.
  6. SteelWheel
    SteelWheel Bobtail Member
    17
    8
    Jun 15, 2012
    After driving the same truck/trailer configuration for a while you get a feel for how much room you need to turn. I just figure that and then a little extra for insurance, as others have said.
  7. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    i usually start by turning the wheel. of course in NJ I hafta turn right to go left
    gb2nyc and dirtjersey Thank this.
  8. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    Slow down and swing out..
  9. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    You get a feel for the truck setup you have. when you come up to your turn look at the way you have to turn, see whats there. is there a curb in the middle is it tight and so on and so on. than line up to make your turn. if i have a tight turn i swing my truck far out. ie if i am turning right i swing my truck into the left lane taking both the left lane and right lane. reasons. gives me more room in the turn keeps cars out of the way and is easier on the truck and trailer. those hard cuts are hard on the drives and the trailer all around.
  10. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    run as fast as you can up to the turn, yank the wheel in the opposite direction, and stomp on the brakes as hard as you can!
    Oh, I thought this was how not to make a turn......
  11. sdlm
    sdlm Light Load Member
    271
    139
    Aug 8, 2012
    To be honest I estimate before I start it and using my mirrors adjust how sharp I am turning in the turn. I switch between 48 and 53 ft trailers a lot, sometimes twice a day, so I find it a bit hard to be 100%, accurate without a bit of correction during the turn.
    By accurate I mean not hitting the curb and not leaving a.big enough gap for a vehicle to get between your tandems and the curb.
    Also, In Patterson, nj where one of my customers is, I have to make the cars back up to make one of my turns, it just isn't possible any other way, if I had a daycab and a 48 maybe, but the people do seem to know they have to back up, I don't have to coerce them much.
    I-80Trucker and dirtjersey Thank this.
