Making up experience
Discussion in 'Questions From New Drivers' started by jpsldaddy, Dec 19, 2012.
  1. jpsldaddy
    jpsldaddy Bobtail Member
    Dec 19, 2012
    Is it possible to make up a company and experience in order to obtain a job? I am having a hard time finding work.
  3. apyles
    apyles Medium Load Member
    449
    142
    Oct 21, 2011
    Newbern,Tn
    What kind of experience are thinking of making up? If for some reason that you did get hired, AND you had an accident,,,,,,,,wow,,, you would have some serious explaining to do, if they decided to run a detailed background check. Some employers will check every last job that you put down, and some will not it's a chanceyou are taking. Why are you having trouble finding a job? What type of position are you trying to get? Local,OTR? Is your DAC or MVR screwed up?
  4. buzzarddriver
    3,528
    10,092
    Feb 1, 2011
    Dallas, TX
    A company is required by FEDERAL statue to list 10 years previous work experience on new drivers. If you made up some of the work you put down, you would be forging a federal requirement and could be prosecuted if found out.
  5. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    That's a bit of a misnomer. While the company is required by federal statute to attempt to CONTACT the listed jobs in the information provided by the applicant, the applicant is required to provide the information as company policy, NOT federal statute or even federal policy. It is NOT a crime to provide false information (yet) on an application for a job of this magnitude. In fact, many job seekers, including drivers, have used http://thereferencestore.com/ with various degrees of success. That being said, it is probably not a good idea to list phony driving jobs as Apyles correctly indicated, IF something should happen, such as an accident, and you can't prove it, it can come back to bite you. If you're looking to create merely a work history. that's a bit less of a dicey roll, easier to pass off and much safer.
    Chinatown Thanks this.
  6. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    What sort of experience are you attempting to fake? If you don't know what you are doing, it will be apparent. Even if you DO manage to lie your way into a job, the fraudulent application is reason enough to terminate you when it is discovered. Doesn't matter if the lie comes to light after a month or after 20 years, most companies will still kick you to the curb when they find out about it.
  7. Chinatown
    Chinatown Road Train Member
    73,908
    166,927
    Aug 28, 2011
    Henderson, NV & Orient
    If you are a driver, try Paschall Truck Lines and Panther Expedite with online applications.
  8. 6daysontheroad
    6daysontheroad Medium Load Member
    462
    698
    Dec 15, 2012
    North of the Rio Grande
    Better to be honest and tell the truth and let prospective employers know you are willing to learn and work hard if they will give you a chance to prove yourself. There are companies that offer traing if you are willing to accept lower pay for a while until you gain experience. Then after a while you can give verifiable experience if you decide to move on to greener pastures. If you make up companies it is real easy to check if they ever actually existed through DOT numbers and such. Go out and put in applications everywhere you can and try not to get discouraged. You will eventually find something.
    Tonythetruckerdude Thanks this.
  9. TripleSix
    128,434
    Ethics.
    Had a guy show up one day, applying for a heavy haul job. Boss asked him if he could work a 9 axle. The guy boasted about his prowess with 13s and 19s. Boss told him to put together the 9. He couldn't. Boss told him to get lost.
    never tell an employer that you have experience and you have none. It's better to walk in and tell them you're a rookie than to lie. Sure, hiring procedures have become much more complex, but one thing still remains the same: you're going to have to take a driving test, load a trailer, set up and shim a flip, slide tandems, do something that an experienced driver can do and be graded by an experienced driver. You may be able to fool an office jockey, but a veteran trucker will spot you instantly for a fraud.
    in my current job, I had to do a driving test with an old school driver that got put behind the desk as a safety man. He asked me if I had driven before and how much experience did I have. We then went on a road test.
    "Tuen here. Left at the light. Right at the 5th light. Turn left. Turn left. Turn right. That bridge that we went under 2 miles ago, what was the height of that bridge?"
    "13'9"
    "You passed."
    We see it every day. Every day, we have someone coming up to us BSing. We can see it 2 weeks in advance. If you apply for a job, odds are you are going to run into one of us, and we are going to have to tell the boss that you're a rookie.
    Speaking of BS, what besides rookie status is making employment hard for you?
  10. Chinatown
    73,908
    166,927
    Aug 28, 2011
    Go to the "Trucking Jobs" thread on this forum then clink on "Seeking employment". Put your info there.
  11. Crypto
    Crypto Light Load Member
    80
    21
    Aug 6, 2012
    Triple Six,
    I'm a rookie and not afraid to admit it but I can drive like someone with 20 years of experience and I can prove it. I don't think its about the experience you have driving. It all comes back the question "Can I have a beer with this guy and trust this guy if I need too!"
