Just when you thought the dot hacked up your log sheets too much? Here comes another puzzle to solve....
Starting July 1, 2013, youll also need to factor in a mandatory 30-minute rest break into the equation when youve reached eight consecutive hours of On-Duty.
When that rule takes effect, youll only be able to drive if youve taken a minimum 30-minute rest period in the previous eight hours.
manditory 30 minute break goes into effect july 1st 2013 ...or so im told
Discussion in 'Truckers News' started by speedracer 1963, Jun 12, 2013.
Page 1 of 5
funny you mention that...i was just looking it up
Petitions for Reconsideration and Replies (PDF)
Summary of Hours-of-Service (HOS) Regulations as of July 2013
The table below [Download PDF Version] summarizes the changes compared to current rule.
[TABLE="class: TableFMCSA1, align: center"]
[TR]
[TH="class: LeftTableHeadFMCSA, width: 15%, align: center"]PROVISION[/TH]
[TH="class: LeftTableHeadFMCSA, width: 35%, align: center"]PRIOR RULE[/TH]
[TH="class: LeftTableHeadFMCSA, width: 47%, align: center"]FINAL RULE - COMPLIANCE DATE JULY 1, 2013[/TH]
[/TR]
[TR]
[TH="class: MiddleTDFMCSA1"] Limitations on minimum "34-hour restarts" [/TH]
[TD="class: MiddleTDFMCSA1"] None [/TD]
[TD="class: MiddleTDFMCSA1"] (1) Must include two periods from 1 a.m. to 5 a.m., home terminal time.
(2) May only be used once per week, 168 hours, measured from the beginning of the previous restart. [/TD]
[/TR]
[TR]
[TH="class: MiddleAltTDFMCSA1, bgcolor: #ACB4BF"] Rest breaks [/TH]
[TD="class: MiddleAltTDFMCSA1, bgcolor: #ACB4BF"] None except as limited by other rule provisions. [/TD]
[TD="class: MiddleAltTDFMCSA1, bgcolor: #ACB4BF"] May drive only if 8 hours or less have passed since end of driver's last off-duty or sleeper berth period of at least 30 minutes. [49 CFR 397.5 mandatory "in attendance" time for hazardous materials may be included in break if no other duties performed] [/TD]
[/TR]
[TR]
[TH="class: LeftTableHeadFMCSA, align: center"]PROVISION[/TH]
[TH="class: LeftTableHeadFMCSA, align: center"]PRIOR RULE[/TH]
[TH="class: LeftTableHeadFMCSA, width: 47%, align: center"]FINAL RULE - COMPLIANCE DATE FEBRUARY 27, 2012[/TH]
[/TR]
[TR]
[TH="class: MiddleTDFMCSA1"] On-duty time [/TH]
[TD="class: MiddleTDFMCSA1"] Includes any time in CMV except sleeper berth. [/TD]
[TD="class: MiddleTDFMCSA1"] Does not include any time resting in a parked vehicle (also applies to passengercarrying drivers). In a moving property-carrying CMV, does not include up to 2 hours in passenger seat immediately before or after 8 consecutive hours in sleeper berth. [/TD]
[/TR]
[TR]
[TH="class: MiddleAltTDFMCSA1, bgcolor: #ACB4BF"]Penalties [/TH]
[TD="class: MiddleAltTDFMCSA1, bgcolor: #ACB4BF"]"Egregious" hours-of-service violations not specifically defined. [/TD]
[TD="class: MiddleAltTDFMCSA1, bgcolor: #ACB4BF"] Driving (or allowing a driver to drive) more than 3 hours beyond the driving-time limit may be considered an "egregious" violation and subject to the maximum civil penalties. Also applies to passenger-carrying drivers. [/TD]
[/TR]
[TR]
[TH="class: MiddleTDFMCSA1"] Oilfield exemption [/TH]
[TD="class: MiddleTDFMCSA1"]"Waiting time" for certain drivers at oilfields (which is off-duty but does extend 14-hour duty period) must be recorded and available to FMCSA, but no method or details are specified for the recordkeeping. [/TD]
[TD="class: MiddleTDFMCSA1"]"Waiting time" for certain drivers at oilfields must be shown on logbook or electronic equivalent as off duty and identified by annotations in "remarks" or a separate line added to "grid." [/TD]
[/TR]
[/TABLE] -
Im trying to get in the habit now.
Now you did it . You're going to start a fresh bunch of complaints from drivers that want to know why they can't do a restart away from their home terminal .
Sublime, Giggles the Original and 123456 Thank this. -
Seriously now for many of you is this 30 minute brake going to affect your hrs?Alot of you are sitting waiting for loads,there is you 30 minute brk.Also add 30 minutes while waiting in the dock.You can make this work without a problem.
Raiderfanatic and moosc Thank this. -
I think it's more of them forcing it. For us night drivers it will be a bit of a problem but I will just find an independent and sit on their fuel island. I think it's stupid and unnecessary but no it shouldn't be that hard. Now the 0100-0500 restart provision is a also a slap in the face. How the heck do they know I sleep better then?allniter, pattyj and zentrucking Thank this.
The problem with that is if you take the break before you have 6 hours on duty you'll have to take another before your 14 is up .
We just recently switched over to AOBR's on all of our trucks, it looks like the system will "adjust,update" on July 1st. It will start a second countdown clock after you start your day as to how much time you have before you HAVE to put your 30 minute stop in.
Between this 30 minute break and no more than one reset, I am glad that we went the electronic log route, no offense, but the truth is, none of my guys are math majors, and I could see that with no second reset and having to roll hours where it could get very easy to make a mistake, or add wrong.Twicebit Thanks this. -
I take a half hour a day already. I am a human, and i am not working like a illegal immigrant for nobody
moosc and zentrucking Thank this. -
Waiting in the dock must be logged on line 4.
For reference:
All 4 of the conditions need to be met in order to log on line 1 after beginning your work day. Take particular note of item number 3.
Page 1 of 5
