Manhattan
Discussion in 'Ask An Owner Operator' started by jaguar011, Oct 20, 2017.
  1. jaguar011
    jaguar011 Light Load Member
    90
    21
    Jan 28, 2015
    Any advice who to get to E 24th street on Manhattan? I will cross George W bridge.
    13-6 height and 80.000 lb
    Thanks
  3. Jrdude5
    Jrdude5 Heavy Load Member
    703
    443
    Mar 26, 2013
    New York, NY
    Take the 178th street exit right on Broadway take it all the way down to 24th remember it's going to be the first exit off bridge but go straight down to Broadway do not I repeat do not get on the Hudson or West side ave! Anything else free to ask.
    jaguar011 and augiedoggie41 Thank this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    If you don't wanna run bway take 1st or 3rd. Hop on the degan (87) get off on 1st/3rd ave bridge and shoot down. Either will work
    jaguar011 Thanks this.
  5. Ruthless
    Ruthless Road Train Member
    9,096
    90,224
    Aug 28, 2010
    The City.
    ....1st & 3rd run north, not south
  6. Jrdude5
    703
    443
    Mar 26, 2013
    New York, NY
    Can also run 2nd Ave all the way too
  7. jaguar011
    90
    21
    Jan 28, 2015
    At Broadway and 59th st there is roundabout. Should I continue on Broadway or take 9th ave before roundabout/7th ave after roundabout from 59th st?
  8. Jrdude5
    703
    443
    Mar 26, 2013
    New York, NY
    Continue on Broadway you are still legal trust me
  9. Voorhees84
    Voorhees84 Light Load Member
    87
    49
    Oct 15, 2016
    Take the degan to the 3rd Ave bridge exit turn right at the light go over the bridge then bear left the bridges are marked 12"6 I think but you make it easy . This puts you on to the east side at 125th street take 2nd Ave all the way down . If you time it right you can make all the lights . Don't take Broadway it'll take an hour to get downtown . You'll hit a redlight every 3-4 lights . Plus than you'll have to cut across town . This way you're already on the east side .
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Broadway, first exit off the bridge straight down.
    GWB is about 110 dollars cash more or less. USE THE UPPER DECK. DO NOT go on the lower. This is important for two reasons. First is post 9-11 prohibition for security and second is that the first exit on the upper deck is right there at the end.
    Do be prepared for a living bridge movement on that GWB. Sometimes the harmonics set up and it becomes alive. As long it's moving all is well.
    Check google earth maps while you are here planning the trip. NYC is not the place to get lost. Remember your 13.6 is NYC's 12.6 posted plus one actual foot. Depending on color of sign and in season of the year...
    Im not certain but there are hospitals you might be passing, make sure you use the city horn in your steering wheel as those are posted quiet zones. Ive crossed swords between Atlantic and several other north south pathways around them before.
    Stay away from the hudson river if at all possible. You will never be able to do that left when needed all that way down.
    Check google earth tonight before you go up there. Have something pictures in mind where you are going. That will help a great deal.
  11. Jrdude5
    703
    443
    Mar 26, 2013
    New York, NY
    Broadway best way I run NYC 5 days a week.
    x1Heavy and jaguar011 Thank this.
