Does anyone know what type of Bellhousing a 9 speed Eaton Fuller is on a 11.1 Series 60? I'm researching into swapping over to a 4 speed HT-740 mechanical, or possibly an ATEC Allison. Not looking for a World(IE, B500) but the older more bullet proof 4/5 speed automatics. The prices are really low now a days. Any more info appreciated. Thanks.
manual to Allison ATEC/mechanical trans for 11.1 Detroit
Discussion in 'Trucks [ Eighteen Wheelers ]' started by freightlinerman, May 4, 2013.
yep, U can with some minor reprogramming with DDRS. But old pre electronic auto makes truck to be THE REAL gas gussler.....
I remember old LIAZ buses with fully mechanical auto. Converting to manual increases fuel milage twice.
What year is the truck? what EEC? I sugest DDEC-III. No J1922 and cant be used with electronic transmission. -
I have a DDEC II, so it would have to be an old 740 or ATEC Allison. Why does it make them a gas guzzler? I've driven the HT740's, they can be a little slow to shift and the gap between gears a bit tall compared to the B500. But, your argument is the electronic is worse than the mechanical Allison, why is that?
I can see the only way - swap ECM with EEC-IV and use Alisson 6 st tranny with electronic control
Old HT-740 got no TC lock up solenoid, no OD. It is enlarged car tranny, really old design. Yep simple and bulletproof, but not modern tranny that lets U save fuel -
Does anyone have a list for a typical conversion from an Eaton Fuller to an Allison B500, 4060 or 4500?
From the top of my head:
1. Bell housing
2. Transmission
3. Drive shaft
4. Shift pad
5. ECU
6. Oil Cooler
Am I missing anything?
