Many tire treads lying on pavement. Preventable?
Discussion in 'Questions To Truckers From The General Public' started by Robert Gift, Aug 18, 2011.
  1. Robert Gift
    Robert Gift Light Load Member
    179
    26
    Apr 21, 2011
    Denver, Colorado USA
    Are there any signs that a tread may come off before it actually does?
    Seems to be more now than ever before.
    Thank you.
  3. Diesel Dave
    9,111
    28,637
    Jan 20, 2010
    Hesperia, Ca.
    You mean "Aligator's" !!! Well if one was to keep the tire's in check (PSI), and notice and dry rot spot's, lump's, etc, it would prevent/help from them coming apart. I myself DON"T run RECAP'S, It's not worth it. I have lost a couple in the past but it was due to casing failure not to mention it was an OLD casing. That's one thing I alway's put priorty, I check my tire's each time im stopped for whatever reason, If one is low I air it up on the spot and check were it's leaking from and have it fix asap.
    Robert Gift Thanks this.
  4. NYROADIE
    NYROADIE Heavy Load Member
    773
    471
    Jun 24, 2010
    Rochester NY
    :biggrin_2555::biggrin_2555:your asking alot there driver! :biggrin_25521:
  5. Diesel Dave
    9,111
    28,637
    Jan 20, 2010
    Hesperia, Ca.
    It's Mr. Owner/operator to you sir.:biggrin_25523:
    dirtyrabbit Thanks this.
  6. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    My tractors tires are in good shape. However I pull a lot of Werner trailers and they tend to have tires that aren't quite so nice.
  7. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    Just a fun experiment ask the guy parked next to you to borrow an air guage:biggrin_25524:
    The results should scare the heck out of you!
  8. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    That has more to do with it than whether the tire was a virgin or recap. 6 to 8 years from manufacture and the tire should be scrapped...even if it's spent that entire time sitting in a warehouse.
    A quality tire that has been taken care of, when sent to a reputable recap facility with a high level of quality control, will be just as reliable (if not MORE) as a virgin tire. Abused cases, old cases, and low-quality cases don't get capped at reputable recap facilities.
    I'd rather run my own case that has been recapped than a virgin that costs the same as capping my own case.:biggrin_25525:
    Diesel Dave Thanks this.
  9. JimDucan
    JimDucan Medium Load Member
    395
    165
    Mar 31, 2010
    It's also RV and boat season.
    Nobody checks their boat tires until they explode.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Some you can see tread seperation. Many are from recaps where the bands are broke inside the tire from being curbed so much. The life of a company trailer tire goes through hell.
    Running down the road, another driver can hear your bad tire long before you can. I've alerted many.
    Summer time from the hot pavement is the worst time of year. That's why you see more now. That and there are more trucks on the road than ever. You will see many around hills as the weight shifts on the trailer finishing it off. 110 psi doesn't help a weak tire either.
  11. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I noticed the other day I have 7 air gauges. I was like how did I acquire all these? Only a truck driver can... or a tire shop.
