MAP-21 E-LOG Mandate (Electronic Log Mandate)
Discussion in 'Trucking Industry Regulations' started by that65, Jan 25, 2014.
  1. that65
    that65 Light Load Member
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    It's real and it's coming, 2 years after final ruling, Map 21 was passed and this is in the law, goggle it and go to the fmca.gov ,look thru there a while and you can pull it all up, P.S. It's either time to band together or I'm getting the hell out.........................
    7.3 cowboy Thanks this.
  3. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    Well, we won't be banding together.............
    Raiderfanatic Thanks this.
  4. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,980
    Apr 4, 2007
    Joetro Thanks this.
  5. that65
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
  6. Roadmedic
    18,951
    8,980
    Apr 4, 2007
    EOBR/ELD Proposal Advances from FMCSA to DOT Secretary’s Office
    No matter if you call them electronic on-board recorders, electronic logging devices, or black boxes, a proposal to mandate their use is slowly winding its was through the bureaucratic hands of the federal government, putting it closer to publication.
    http://www.truckinginfo.com/channel/owner-operators/news/story/2013/06/eobr-eld-proposal-advances-from-fmcsa-to-dot-secretary-s-office.aspx
    http://www.fleetequipmentmag.com/mandated-eobrs-elds/
    Electronic onboard recorders (EOBRs)—or electronic logging devices (ELDs), as they are now being called—installed in commercial vehicles can monitor and record a whole host of data about a vehicle and its driver. And because ELDs are the subject of a pending mandate that will require them for tracking hours of service (HOS), fleets are beginning to pay very close attention.
    Since they track much more than HOS—electronic vehicle inspection reports; driver behavior reporting on speeding, idling and hard braking; and integrated map and route solutions, to name a few—many fleets have adopted ELDs ahead of the mandate in order to reap a multitude of benefits.
    “The effective date for enforcement of the mandate is two years after issuance of the final rule, most likely later in 2016—this is to allow the suppliers to update software to meet the compliance of the new regulation,” Schenk adds.
    Omnitracs’ Kraft explains that part of the reason for the lengthy schedule is the extensive scope of the EOBR mandate rulemaking. Key areas to be addressed in the upcoming proposed rule include:
    • ELD mandate and requirements for these systems as directed in MAP-21.
    • Technical performance requirements that were addressed in a prior 395.16 EOBR rulemaking—with several updates recommended by the Motor Carrier Safety Advisory Committee.
    • New guidelines to mitigate the potential for driver harassment as required in response to prior litigation.
    • Additional requirements for compliance records management by the carrier’s support system, based on a previous proposed rulemaking that was delayed.
    “While it’s hard to determine a final implementation date, I can note that once the final rule is ready the industry will need 12-18 months to develop and bring certified products to market,” Kraft says. “Then, once the products are available, it is expected the industry will need an additional 24-36 months to implement EOBRs into more than two million trucks that have not already installed one. We also expect a transition provision that allows carriers that have implemented current EOBR systems in advance of the final rule to continue the use of those systems for their remaining useful life.”
    that65 Thanks this.
  7. runningman0661
    5,136
    14,748
    Mar 5, 2009
    Clover, South Carolina
    Well you might as well hang up the keys because it will happen. Either adapt or find another career.
  8. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    I'm missing something here ...we've been running E logs for the past two years.
    So they are going to mandate what we already have in the trucks ?
    i don't understand the drama in this thread
  9. that65
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    LOL, your right, shouldn't of started this post, anyway just trying to get the word out.
  10. that65
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    It's not a law, your company put those in there
  11. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    And this is what some people believe.....
