Hey Guys/Gals,
I wondering if someone could recommend the best Road Atlas to download? Ol' Rand seems like its going to win out but if I'm going to buy this tool I want to best there is. My tablet has made searching for locations, in cities for sure, much easier.
I will be using my tablet the most as it is fast and easy to pull up maps of city streets and I have a much larger view than my phone provides but I'm sick of using my data time for this process.
I DO NOT NEED A GPS...............I WANT MAPS ONLY........DATA PACKAGE FREE!
Downloading maps.
Any advice, experiences welcomed!
Thanks,
Bryan
Maps Downloaded to PC/tablet
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by texan007, Oct 21, 2012.
Page 1 of 3
Try copilot. I have it on my phone and aunts tablet
it's also what i started with. before buying an actual unit that got traded in for pcmiler which is made by copilot.Last edited: Oct 22, 2012
I would definitely go with a real GPS unit. The cheap ones that run off data will get you stuck of you're in a boondock. Real GPS uses satellites, not data. Saves time and money.
Really, just get a cheaper truckers GPS, to start off with. Then later on grab a more expensive one.
It might be a real hassle having to stop traffic, go off route or miss a turn because you're not going to be able to stare at the tablet the whole time lol. -
I've said it before, but a good pc based system is MS Streets/Trips. $69 and do the megafile poi download.
Yeah Streets and Trips is about the best PC software.
I personally like Google Maps because you can see real life and see street level and signs.
Trucking software isn't 100% reliable. They take standard Navteq routing software and modify it. What have they missed?Dieselboss Thanks this. -
Thanks for the Streets and Maps suggestion.
I DO NOT NEED ANOTHER GPS.
I just want maps that do not use my minutes. I already have a great GPS but I like to know where I'm going first. I the city is no place for a mistake that ONE GLANCE at a map would correct.
Again guys I want map....ACTUAL maps...just in digital form vs. paper -
copilot gps. $3.99. ;can't get any cheaper then that.
it works for trucks. and requires no internetDieselboss Thanks this. -
Just maps? I agree with MS Streets as a cheap, but good one for laptops, and CoPilot for Android or Apple (non-truck version if you are keeping the cost low)
So basically I'm backing up both Snowy and Condo depending on what the device is. Your thread says "PC/Tablet." So I am assuming that you mean a Windows-based machine. -
Since you don't want GPS, you can get MS Streets/Trip for about $35. The $69 is with GPS module (nice backup). The program goes right down to invidual streets in cities/towns. I used to use the non-gps version in a service repair business with very good luck.
Page 1 of 3
