Marker light dimmer/flasher not working on a trailer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jacoooooooo, Nov 27, 2019.
  1. Jacoooooooo
    Jacoooooooo Heavy Load Member
    747
    1,054
    Oct 20, 2013
    Hello everyone.
    So I picked up a brand new Wilson trailer and I cannot dim/or flash marker lights on it using the button on a steering wheel on my truck (Volvo). They do dim/flash on a truck, but nothing happens on a trailer. Worked just fine on every other trailer I had before.
    What could be the reason?
  3. loudtom
    loudtom Road Train Member
    1,717
    2,801
    Aug 26, 2016
    One wire feeds the clearance lights, the other is marker lights or something. It's possible that they wired the whole trailer to be on one wire, which happens to be the one that isn't linked to the switch. Should be the brown and black wires on a 7 round plug.
    Jacoooooooo Thanks this.
  4. Oxbow
    Oxbow Road Train Member
    12,816
    132,737
    Nov 24, 2015
    Most likely a jump wire between the black and brown wires like @loudtom stated, probably right where the wires attach to the back of the female plug on the trailer.
  5. Jacoooooooo
    747
    1,054
    Oct 20, 2013
    Means that I will not be able to fix it?
    It’s a Grote wiring on the trailer.
    I would think it should be standardized.
    Or, ok I see. So maybe I could swap those cables on a 7-round plug than...
    Oxbow Thanks this.
  6. Oxbow
    12,816
    132,737
    Nov 24, 2015
    Well swapping on the male (pigtail) won't help. If you remove the receptacle on the trailer you will likely find a jump wire between the brown and black. Should be able to just remove the jump wire.
    Edit to add: it will be the wires on either side of the bigger top wire which is the ground.
