Marker light
Discussion in 'Experienced Truckers' Advice' started by MexTrucka909, Jun 4, 2018.
  1. MexTrucka909
    MexTrucka909 Bobtail Member
    21
    20
    Feb 13, 2018
    24112
    hey guys i recently found i have a trailor top marker light out.. can i just take it out and be legal? Thanks in advance
  3. BlackThought
    BlackThought Medium Load Member
    566
    463
    Jul 22, 2014
    Memphis,TN
    Top as in 13'6 high?
    Bring it to shop.
  4. Ridgeline
    22,687
    121,742
    Don't you have that little book that is green with all the regulations in it?
    stwik and Bean Jr. Thank this.
  5. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    You only need the middle 3 lights. Far as I know. Lights that are not needed can not be ticketed for. Such as chicken lights etc. Don't mean you won't get a level one though.
    Bean Jr. Thanks this.
  6. blairandgretchen
    13,835
    75,739
    Dec 9, 2011
    South west Missouri
    Yeah, you need the top three on the rear of the trailer, at least.
    Off to the chrome shop and install 15 blinding LED’s - rates are good right now, you can afford it. :)
    Bean Jr. and Oldironfan Thank this.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Define marker light. No, seriously...
    If it's one of the required ones no, as it's well, required.
    If it's a non-required light it's fine to even leave as-is.
    Here's the law with the highlighted portion that matters.
    §393.9 Lamps operable, prohibition of obstructions of lamps and reflectors.
    (a) All lamps required by this subpart shall be capable of being operated at all times. This paragraph shall not be construed to require that any auxiliary or additional lamp be capable of operating at all times.
    And here is the required lights.
    eCFR — Code of Federal Regulations
    Bean Jr. and blairandgretchen Thank this.
  8. sbaumann14
    sbaumann14 Road Train Member
    1,235
    1,430
    Sep 1, 2010
    Rhinelander, WI
    If u gonna climb up there to take it out, why not replace it?
    fargonaz, magoo68, Bean Jr. and 5 others Thank this.
  9. Judge
    90,898
    Old DOT rule is, if it’s on there, it has to work, so if you take a hammer and bust it out, it’s no longer there, but it’s still a required clearance light, you might be able to put reflective tape there, or just change the light/get it changed.
    2 points on license x2 for first year,
  10. ZVar
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    And yet someone else not reading. You are 100% wrong.
    Dumdriver, kylefitzy and AModelCat Thank this.
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,560
    9,923
    Mar 30, 2014
    New regs, or understanding the regs more accurately, if it is required, it must work, such as tail, brake turn signal and certain marker lights. If it is not required, it is not required to work, chicken, mirror, fog and excessive marker lights.
    If it is required, knocking it off doesn't help and if it's not required, there's no need to knock it off.
    ZVar and not4hire Thank this.
