Marker lights won't turn off 387
Discussion in 'Peterbilt Forum' started by conejosriverts, Jan 3, 2015.
  1. conejosriverts
    conejosriverts Bobtail Member
    14
    4
    Nov 25, 2012
    I have a 2006 387 and my marker lights stay on all the time. Switches of, key off, park brakes set and lights still on. Headlights go off when switch is off, but not marker lights. Can't find the issue. Someone please help.
    Thanks
  3. FozzyNOK
    FozzyNOK Road Train Member
    2,452
    3,774
    Jul 18, 2007
    Oklahomistan
    This is probably not what is is.. but.. it the switch a "three position" switch? ON - OFF - MARKERS... ?? Make sure the switch is in the middle position maybe?
  4. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Have seen this happen before. Sometimes batteries are changed and cables not tightened down enough. Eventually negative cables vibrate loose enough to where they make intermittent contact and cause weird issues with various lights not shutting off or staying off. Tighten em up.
  5. conejosriverts
    14
    4
    Nov 25, 2012
    Thanks but cables all tight and only two position switch.
  6. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    Find the relay and unplug it, if the lights go out, swap it out with another identical relay to see if they stay out, if the lights are off with the relay unplugged, but stay on with the swapped relay, unplug the switch.
    kylefitzy and conejosriverts Thank this.
  7. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Pull wires off switch and if the lights go off then switch is bad. In a pinch you can use another switch that maybe an extra or you don't use
    conejosriverts Thanks this.
  8. conejosriverts
    14
    4
    Nov 25, 2012
    both great ideas, tried them already. lights stayed on with switch unplugged and with a swapped relay. very frustrating and confusing
  9. gudethangs
    gudethangs Bobtail Member
    23
    Dec 14, 2014
    Remove battery cable from batteries for about a minute. Then replace them.
  10. Lyle H
    Lyle H Road Train Member
    1,289
    2,932
    Apr 16, 2014
    Did this just start happening?
  11. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
