Mary Nichols....You Suck!!!!!
Discussion in 'Trucking Industry Regulations' started by Working Class Patriot, Mar 21, 2012.
  1. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Thanks to you and your wacko associates from CARB....O/O's like myself are getting screwed with your regulations...
    Our engines are all POS.....
    I was informed by a Cummins rep that over 50% of all trucks requiring service at Cummins are EGR failure related issues....
    Downtime is killing us Ms. Nichols....Unlike you and the rest of your taxpayer supported cohorts....We O/O's have to work for a living....
    We can't afford to miss a week of work....
    Your over-regulations regarding truck engines are killing us....Mandating unnecessary crap on engines that cause multiple problems..
    The EGR coolers are junk....They cause a cooler combustion....Resulting in more soot....So then you mandated DPF's which are also failing at a less-than-acceptable rate....The end result...More downtime...More lost revenue....
    What say you and your fellow supporters in government?
    :biggrin_25510:
  3. Mastertech
    Mastertech Staff Leader / Admin Staff Member Administrator
    117,210
    29,335
    Dec 28, 2007
    3rd Rock From The Sun.
    It's the same thing on pick up trucks too Ron.
    The EGR valves and coolers are absolute junk. It's amazing the number of failures I see. Oh and lets not forget about those junk VVT turbo's. We have all this crap on these vehicles now and the fuel mileage on some trucks is worse than ever. What a joke.
    EPA has ruined our diesel trucks IMO.
    GuysLady and bullhaulerswife Thank this.
  4. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    I know....My EGR cooler failed on my 1 ton two years ago.....Ford had to pay for it...It was still under warranty....
    My Pete however is not as "lucky"....
    It's been in the Cummins shop since Monday....Initially it "coded" the EGR valve (Just replaced at Grand Junction Pete on the 8th of this month)...the EGR cooler....Now the VGT is wacked out on tolerances..so that has to be replaced....
    On top of that...I'm fighting a warranty registration issue with Peterbilt....
    However...The GM at Rush Tulsa....Is seeing what he can do to help....
    Cummins CAL-Pacific-Bloomington (I absolutely refuse to take any of my equipment to Rush Pete in Fontana...They suck!!!!!...Their wait-time is ridicules...Three days....) deserves a big time hat tip though....Deanna at CCP is earning her pay +++++++:biggrin_25514:
    GuysLady Thanks this.
  5. Stump
    Stump Heavy Load Member
    769
    663
    Jan 27, 2009
    Modesto CA
    I live in California and run a older truck. I wont buy one untill there is a law, if not, upgrade to a filter or one of the alternitives. As for Cummins, the Cams breaking is the biggest of the many problems with the ISX.
  6. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    How old is old?
    You can't legally run a mechanical engine in Cali.....
    In 2014...The oldest engine you can have is an '07 EPA.....
    I think that Nichols and CARB are out to shut the trucking and construction bizzes out of Cali....
    Price out a DPF for a CAT Heavy Duty Engine like one you would find on a D12 High-track.....
    It will make you sick......
    Not only that....CARB considers the "Useful Life" of equipment from trucks to dozers as 10 Years!!!!!
    Really?!!!!!!!:biggrin_25510:
    I worked for contractors that had trucks from the 40's-70's...Dozers....Blades....Sidebooms from the 50's......And they still all ran....And they were all PAID FOR....EARNING MONEY...NOT COSTING MONEY!!!!!!
    However CARB thinks that PACCAR....CAT....JD....Among the other OE's...Just give this stuff away......:biggrin_25526:
  7. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    thats why i have a 2003 truck with less epa ########, its messing up trucking, that is unless your a company driver and they could care less with a huge fleet.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    And don't forget the lead scientist for CARB got his degree in a box of cereal, and they STILL stand by him. They all ought to be in jail.
  9. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    This issue is another reason why I tell brokers that anything under $2/m is cheap.....And some of them say I'm "greedy".....
    Many of my shippers and receivers now require CARB/EPA compliant rigs....Yet the brokers still think that $1/m "cuts it" for a rate......:biggrin_25526:
    keepntruckin Thanks this.
  10. LSAgentOZR
    LSAgentOZR Road Train Member
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    This is what you get for voting for Obama! Think about that next time you go to vote for "someone besides a Republican/McCain.":biggrin_25522::biggrin_25523:
    gearjammer-2000 Thanks this.
  11. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    CARB is the "brainchild" of Governor Moonbeam back during his first term as governor of Cali in the early 70's....The EPA modeled their regs after CARB....
    My wife's cousin's husband works for AQMD in Diamond Bar Cali.....The AQMD thinks Nichols is a living "Goddess"...:biggrin_25526:
