Math in Trucking
Discussion in 'Questions From New Drivers' started by Rocknroller4, Apr 25, 2016.
  1. Rocknroller4
    Rocknroller4 Road Train Member
    1,165
    613
    Nov 25, 2015
    Just wanting to know what area of trucking requires the math to be completely accurate. Only thing I am concerned about is trip planning and paperwork. Math has never been my strong suit. I know the Qualcomm manages most of the hour stuff.
  3. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    That's really not worth worrying about yet
    There isn't much out here you need to be very accurate about math wise.
    Weights, add em up for a rough estimate. If it's close you need to scale.
    Trip planning, miles/60= hours needed + mandatory breaks.
    After a month you'll be able to give a pretty good guess without much thought anyway.
    BillStep and Rocknroller4 Thank this.
  4. NewbieTransport
    NewbieTransport Light Load Member
    71
    29
    Jan 13, 2016
    Central Florida
    i'd say your hours driven per week and total miles driven loaded or empty. you want to know some basic algebra to add up those hours and miles at the end of the week to compare it with your payroll.
  5. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    You will need basic math to calculate hours to be gained in order to properly plan trips and know whether you have the hours to complete a load when offered/dispatched on it. If you plan on being successful longterm there is a great deal of math involved in trucking, but none of it is overly complicated nor is it anything to be worried about when you first start out.
    Dan.S and Rocknroller4 Thank this.
  6. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    If you can use a calculator and do simple math, then you'll be fine. (60mph is one hour to drive)
    Miles driven/gallons used =mpg
    Revenue divided by miles driven is rate per mile
    Expenses over mile is cost per mile
    Dan.S, BillStep and Rocknroller4 Thank this.
  7. kw550cat
    663
    596
    May 22, 2012
    brooklyn, new york
  8. Moose1958
    Moose1958 Road Train Member
    15,159
    33,354
    Dec 17, 2010
    Williesburg, Virignia
    The one area where you must be accurate is your hours. DOT does not have much tolerance if you go over your hours.
  9. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Bridge height and weight restricted bridges.
  10. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    It's 21;00 and you have to wake up at 4:30,
    How long do you set the timer on the Screaming Meanie?
    rabbiporkchop Thanks this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Pop it onto the platform scale. Write down gross weight. Move the front axle off. write the lower gross weight down. Subtract. You now know your front steer axle weight. Don't forget to use your trolley gently to float on the platform or you will throw the readings off with your service brakes.
    Move until your drives are off the scale. You now know your trailer tandem weight, hopefully the number is less than 34,000 back there for two. If you have a 10 foot spread axle, you can pack 40,000 back there. 20K on each one. Subtract your trailer weight and steer weight to discover your tractor drives weight.
    There I hope that I wrote it out as I remember it should be.
    having the math wrong and being too heavy somewhere is going to cost you money.
    Rocknroller4 Thanks this.
