I have a 2004 tri-axle midland end dump trailer and I was recently told by a highways engineer at a job I'm doing that they want me to put the maximum height on the side.
I've phoned dealers and all I can get is an approximation of about 11.6M high. Anyone know the actual max height of an end dump made by midland or where I can go to find out? I don't have a measuring tape that long.
Cheers
Max Height of end dump trailer?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Disturbed Canuck, Jul 12, 2009.
never seen a bucket with more than 72" sides maybe they want walkin floors what kind of material is it it better be very light stuff
Down here in USA i believe DOT requires height marked over 10'(about 3 meters). I have never happened to be on a job where dumping height was required on trailer. As long as wires etc werent taken down, no one cared... -
Well when you work with government chaps, they can get a tad bit anal. Dept' of highways likes to work by the book.
So far as I understood, yeah the engineer wanted me to put the height when dumped and all stages are up on the cylinder.
Cheers -
I would be telling the engineer to get his ruler and measure it....tell him to sit on the head board and take a ride....when he is at top of dump, tell him to get you a measurement.....
does the engineer know the height of everything on site, that you would be close to while dumping?
if you aint ripping anything down while dumping, who cares.... -
Some roading jobs over here will only let bottom dumps work on them,why don't you tie a string to the front of your trailer then put it full hight then measurer the string??
