Maximum load on steers
Discussion in 'Ask An Owner Operator' started by Crazy Alex, Jan 31, 2015.
  1. Crazy Alex
    Crazy Alex Light Load Member
    161
    46
    Dec 1, 2012
    Here n there
    Whats the maximum on steers?
    My steers say 6175 Maximum load,so that makes 12350 lb,right? All states agree with that?
  3. mrbmg
    mrbmg Bobtail Member
    38
    14
    Aug 6, 2010
    You might pass for 12350, just depends who you come across but I never go pass 12.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    More or less, you cannot exceed the weight rating of the axle though.
    double yellow and Cetane+ Thank this.
  5. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    On my old Pete, I never had 12 on the steer. I usually had the 5th wheel slid back, it rode better, and steered easier. (armstrong steering) I think the most I ever had was 11 once. I didn't have many scales to cross, and if I had a heavy load, I'd just go around them. Nowadays with setback steer axles, you can be over on the steer pretty easy.
  6. reefer101
    reefer101 Medium Load Member
    444
    246
    Oct 24, 2014
    vnl780 have 13000lb that means you have to borrow from drives or trailer
  7. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    i weigh 12,400 with full tanks. haven't been stopped yet.
    the general weight rating will be 12,350. that's pretty standard tire rating.
    Cranky Yankee Thanks this.
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    It is the lowest of the following:
    Axle
    Tire
    Road
    Some axles are only rated for 12,000; others 12,350, 12,500 13,000, 14,000 etc. Check door plate (or better yet- the axle)
    Steer tires are typically rated for 6175 - 7830lbs. Note that it is possible to exceed 6175 lb on one tire without exceeding 12,350 on the steer axle...
    The national network of roads is rated for 20,000 lbs on a single axle, but other state highways can be rated for less; Arkansas, for example, has a 12,000 lb limit on steer axles (and for a while they were incorrectly citing people on the national network).
  9. 201
    12,621
    25,905
    Apr 16, 2014
    Years ago with just the small scales, (Ill and some Wis. scales) they wouldn't even check the steers.
  10. kemosabi49
    10,901
    47,289
    Jan 13, 2013
    SW Arkansas
    For this info you can look at the tables in the front of the Rand McNally motor carriers atlas.
    blairandgretchen Thanks this.
  11. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Yeah, you can go over 12,000 on a steer axle. How much is determined by the rating of the axle and tires, and also that you are not over total gross weight. I have gone over 12,000 up front many times over the years, and I have not had a problem from any of the 48 states, yes, even when crossing the state scales. Now, you go up to 13K, you had better have a 13K rated axle and tires to match.
    Crazy Alex Thanks this.
