Maximum Road Speed Adjustment
Discussion in 'Volvo Forum' started by nutcase, Jul 28, 2014.
  1. nutcase
    nutcase Light Load Member
    259
    100
    May 2, 2010
    Meridian, ID
    I have a 2014 Volvo with the D13 engine. On the newer Volvos you can no longer set the maximum speed from the dash. Is anyone aware of another method or an aftermarket product that can be used to set the maximum speed that does not cost an arm and a leg?
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    have you checked a Volvo dealer? prob cost about 100 bucks to have done
    Grumppy Thanks this.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Wait, how can you set the max speed from the dash to begin with? This is interesting...do tell. What year and what engine were you able to set it on before prior?
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    dashboard speed limit is user speed limit. but there is factory speed limit u can change with volvo software only
  6. nutcase
    259
    100
    May 2, 2010
    Meridian, ID
    My last truck was a 2007 with a D12. You could set max road speed and rpm if you had the password to access that part of the menu. Sometime after Ontario and Quebec came out with their speed limiter laws Volvo disabled those features. I don't know when it took affect.
    Trying to find a way to change the max speed other than going to a dealer every time I go to Ontario(which isn't often so far.)
    Volvo says there are people doing it but couldn't say what they were using.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    and don't say Tune on here or this thread will be deleted.:biggrin_25517:
  8. Trucker2211
    Trucker2211 Light Load Member
    94
    91
    Mar 3, 2015
    Has anyone ever found a way to do this yet? I am wanting to do the same thing and I have the same truck only mine is a 2015. Would a dealer even change the max speed setting if you're not the actual owner of the truck? I do know mine is not password protected.
  9. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    You need Vcads software......you can find Chinese rip off stuff for a few hundred dollars to do it yourself.
    CoyoteExpress Thanks this.
