When shifting this tranny at what RPMs should I split the top 4 at? Idk if it’s me or the truck but I cannot for the life of me split these gears. One guy told me shift the full gears at 1800 and split gears at 1500-1600. I can shift anything Eaton in my sleep not sure what the deal is with this truck and I don’t want to tear anything up unless the tranny is already going, has 460k on it. I’m also not the only guy who was having trouble with it.
Maxitourqe 18 speed
Discussion in 'Questions From New Drivers' started by Woodchuck88, Jul 1, 2018.
Never driven a Mack 18 speed, but I do know that some Mack trans can be tempermetal. They seem to have a rougher feel than others.
Woodchuck88 Thanks this. -
Rpms depend on the engine, not the transmission.
My limited time in a Mack was a truck that was designed for very high rpms, regularly went over 2k, I think cruising rpms were around 1700.Lepton1 and Woodchuck88 Thank this. -
With that having been said, if I'm going uphill loaded or trying to get up to speed in a hurry (such as merging onto the highway), I'll run it up to 1800 or so so that I'm in the peak power band in the next gear. If I'm just accelerating normally, I might shift at 1600 and just keep easing it up to speed. Like I said, the RPM at which you initiate the shift doesn't matter, because it'll drop the same RPM either way. You just want to pick your shift point to keep the truck in its power band as you're accelerating up to speed.Lepton1, Dino soar, Broke Down 69 and 1 other person Thank this. -
