Hi, i have a international workstar 2007 with a maxxforce 11 and we have a big problem, the truck was left 2 week outdoor without beeing used, and after 2 weeks,when they wanted to start it again, it dosent started, so now we start, we pluged the computer and no code was founded, so we guest a fuel problem, we had change filters, bleeded the system and do some pressure test, our ipr and icp are commutating togheter and we dont take chance,we had some in stock so we changed it, after priming the truck with the priming pump, we turn the key and the truck turn and do a sound like it want to start but after 2 second, do a loud sound, no explosion, like the system is not prime, if we block the return hose of the filter, the motor want to start but after 3 second of running, stop, so i ask you, witch step we've missed, how can we find the problem
maxxforce 11 do not start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tomlang, Feb 19, 2014.
Ok, sounds like you have a Maxxforce DT, 9 or 10. The 11 series is the same as the 13 and they do not have ipr or icp sensors/regulators. If you have ServiceMaxx computer program you should be able to see fuel delivery pressure build up to at least 30 psi while cranking. Your ICP pressure should be over 700 psi to start the engine. Make sure you are not reading ICP desired because that is what the ECM is commanding. There is a schrader valve on the side of the intake manifold that looks exactly like a tire valve, this is where you need to bleed the air out of the fuel. Some engines have them at the front, others are at the middle area. Remove the cap, press in the center valve and use the hand primer. You should see fuel flowing out. Make sure it is all fuel, and not air. If there is air, keep priming until it comes clear. Make sure there is oil in the engine. Crank the engine and watch the gauges. You should see oil pressure come up and the tach needs to show some RPM, this confirms the oil pressure is working, and the ECM is seeing rpm. The biggest thing is going to be your fuel pressure. Make sure it is developing fuel pressure too.
x1Heavy Thanks this. -
Alright, I'll see this tomorrow, thank you for your answers! I dont remember if it have a fuel pressure sensor or i have to put a gauge on the quick coopler to know the fuel pressure?
I think all Maxxforce have the fuel pressure sensor. But you could also put the manual gauge on too. Good luck!
ok, I cannot wait for a night so now i am at the garage, i blead the purge valve like you said, air was kept in , but now, my motor started and 2 or 3 second later, it stop, like there's not enought fuel , but my delivery pump work and my delivery pressure dont seem to drop while the engine is running
Remove the air filter and make sure nothing is in there, also check the exhaust pipe. How much fuel pressure is the engine making? How about the ICP pressure?
So, the problem is solved, it was the DPF, ive Never seen a DPF stuck like this, there was nothing that Can pass thru, Thanks for your help! Really apreciate
Heavyd Thanks this. -
I researched this issue a little bit and some people pointed to the check valve on the fuel filter housing. I have yet to replace that valve, but I wanted to see what your input was on this. They recently replaced all 6 injectors in the past year. 3 of those injectors they replaced in the past week. When they replaced those 3 injectors, they replaced the high pressure oil rail o-rings and seals. They also replaced the ICP sensor on the rail. Any advice will help! Thanks. -
What happens to the fuel pressure once it starts to stumble and die? I think you are looking at a base fuel pressure/supply issue.
avgdzlmekanic Thanks this. -
