Maxxforce derate says scr error but the laptop isn’t showing anything wrong
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Maxxforce mess, Nov 29, 2023.
  1. Maxxforce mess
    Maxxforce mess Bobtail Member
    I have an International Lt with a Maxxforce engine. It set a code of 5246. Scr error. Changed bad Nox sensor. Done several forced regens but the derate & Scr error code still on. The mechanic has run every test in the book. Everything seems to be working properly but the Scr error still shows up… Why?
  3. JB7
    JB7 Heavy Load Member
    788
    1,215
    Dec 13, 2022
    Laurel, MD
    Are you saying that the mechanic cleared the code and it comes back? Or that he was not able to clear the code? Or did the mechanic expect the code to go away by itself after the sensor was replaced? Try disconnecting the battery for 5 or 10 minutes, reconnect, start the engine and see what happens. If you still can't get rid of the code the next step would be to have the ECM updated.
  4. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    That code is for SCR driver inducement, meaning you drove too long with an active fault. Those codes cannot be cleared with generic software. You need to see someone with Navistar Engine Diagnostics to reset the SCR fault reset request parameter.
    IH9300SBA and JB7 Thank this.
  5. Goodie123
    Goodie123 Bobtail Member
    5
    Feb 19, 2022
    This one I use and it resets most codes so far https://amzn.to/44zUOJ3 before this one I used the cheaper versions and options,but this one saves money after ONE USE!
  6. Inderjit
    Inderjit Heavy Load Member
    723
    708
    Sep 17, 2017
    You need to force a regen then the driver inducement code should go inactive then it can be deleted.
