May be a silly question but do you guys keep these on blue at ALL times?
Discussion in 'Questions From New Drivers' started by xzmpt, May 28, 2024.
  1. xzmpt
    xzmpt Light Load Member
    86
    80
    Nov 22, 2022
    I constantly have them on blue even over night when sleeping. Is there anything wrong with this? If I’m not mistaken, blue means the air is coming from outside and when the blue light is turned off it means the air is circulating inside? Does blue light equal more outside fumes getting into the truck when you’re parked at a truck stop over night?
  3. tscottme
    tscottme Road Train Member
    In the Pic blue light on means no fresh air. That setting is meant for brief period, not full time use.
  4. xzmpt
    86
    80
    Nov 22, 2022
    So is it bad having the blue lights illuminated all the time? When I sleep for the night, should I turn them off? I feel as though if there’s trucks next to you emitting exhaust fumes, wouldn’t that pull in bad air also?
  5. Lazer
    Lazer Road Train Member
    1,804
    2,880
    Jan 22, 2017
    Depending on the truck, that blue light indicates the statues of the a/c system. Blue light illuminates, indicating the system is ‘on’, no illumination the system is ‘off’. That ‘max’ button you see, press that while the a/c system is ‘on’ and that button may light up, that will ‘recirculate’ the air inside the cab, thus maximizing the cooling of the air.
    xzmpt and Grumppy Thank this.
  6. tscottme
    Leaving the recirculation/blue light on all the time is like wearing a plastic bag over your head. You are re-breathing your exhaled breath. If you are smelling exhaust smells in your truck you have an exhaust leak that needs to be fixed. I would only turn on the recirc/blue light like on rainy days and your windshield fogs up after you get back in the truck. Turn on recirc & run defrost.
    xzmpt Thanks this.
  7. RockinChair
    RockinChair Road Train Member
    5,140
    13,019
    Feb 19, 2012
    CC, TX
    You've got that backwards. When the blue light is off, fresh air is being drawn in from outside, and when the blue light is on, the air inside the cab is being recirculated.
    I keep mine on recirculate (light on). But I run in a hot, very humid area so my A/C needs all the help it can get.
