MBE4000 Boost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sergk1989, May 30, 2016.
  1. sergk1989
    sergk1989 Bobtail Member
    39
    10
    Jan 23, 2013
    How much boost are you guys pushing on your mbe4000?
    I get about 22-23 psi. Is that normal or do I got a leak somewhere?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Big POWWWWWA!!! Lol
    sounds about right .
  4. sergk1989
    39
    10
    Jan 23, 2013
    oh you got that right!!!
    going up I26 from NC to TN about 13K LBS Im going about 27MPH. The Detroit I had in my volvo boosted up to 30PSI
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Maximum boost of OM460 is 30 PSI. Over 30 psi it throws overboost fault code
    25(2)+2 Thanks this.
  6. sergk1989
    39
    10
    Jan 23, 2013
    So I am leaking boost somewhere?
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    MBE got closet crankcase vent system and if u have leak - u can see some oil there.
    But low boost may be related with exaustm manifold leak ore stuck turbo brake ore reed valves, egr (Euro-III/EPA 2002 engines), clogged DPF....
    sergk1989 and toss009 Thank this.
  8. sergk1989
    39
    10
    Jan 23, 2013
    I will be taking a look at the egr system, I have a feeling it's the problem.
    It got worse today, I was going up the mountains with a heavy load and now only 19 psi, couple times it went up to 21psi and you feel it, then after a second back down to 19.
    How can I bypass the egr completely? Can I just unplug the egr valve connector when the engine is cold?
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    to do it u have to reflash ECU, but.... DDCT cant do it. I have to take apart ECM, remove flash memory (AM20F400BB) and reprogram it on bench.
    I have Mercedes Star Diagnose to work on MBE engines.
  10. sergk1989
    39
    10
    Jan 23, 2013
    Oh ok thanks, another question can you upgrade torque on this engine I have 450 hp 1550 torque
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    max torque for this engine is 2200 NM
    but.... there are torque correction values in its eeprom
    may be changed with MiniDiag ore Star diagnose with relevant key.
    The true is that correction may be from 90% to 110% in four points.
