Mbn cat ecm reflash
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gfunk939, Sep 2, 2022.
  1. gfunk939
    gfunk939 Bobtail Member
    I have a mbn that the turbo went out and instead of buying a $3000 oem turbo I got a non waste gate turbo from full tilt but with that I’m running a stock ecm 475 hp. Is there some tuning I can do to wake her up I don’t want to get crazy hp 600 is max as long as it’s safe. I got money so..
  3. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    Once getting rid of that weak factory turbo most people get it flashed with a 6NZ file, it should make it a whole new truck as long as everything else is in order, and you can actually get some fuel mileage out of a MBN then driving sensibly.
    spsauerland Thanks this.
  4. High Stepping
    High Stepping Light Load Member
    52
    25
    Oct 29, 2020
    100% Agree! It's quite a different animal after a 6nz tune.
  5. gfunk939
    Ok great thanks! Yeah the motor was out of framed 200k ago so she’s got some life left in her
  6. gfunk939
    Would cat flash it to 6nz or?
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Doubtful but they might.
  8. Cdemars316
    Cdemars316 Heavy Load Member
    816
    4,912
    Nov 10, 2018
    Cat won't do it, I have the 550 file in mine and it is night and day, went from 5ish to 6.25 on fuel mileage, looking at different turbos now, what turbo did you go with? I just regeared down to 2.74's so I need something that boosts good on the lower rpm range
  9. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    How low of rpm are you planning to run?
  10. Cdemars316
    816
    4,912
    Nov 10, 2018
    Once I get everything set my cruise rpm should be right around 1300-1350, its pretty flat where I run, actually really flat, I went from 3.55's to 2'74's simply for the fact that alot of the winter the wind is so brutal even the most aero trucks have trouble pushing any speed, when it is like that I will be in direct going my 60-65, and when I turn around and the wind is pushing me I can make up for it in od and get really good mileage
