Mechanical N14 Parts Help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hopeaholic, Dec 3, 2020.
  1. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    I like that solution to the idle adjustment. Some of the best tools you create yourself.
    spsauerland and BoxCarKidd Thank this.
  3. Hopeaholic
    Hopeaholic Bobtail Member
    47
    15
    Nov 7, 2018
    American ingenuity; fitting on an old mechanical motor where the computer doesn’t do all the thinking for you
  4. Hopeaholic
    47
    15
    Nov 7, 2018
    Code 5511
    Would be awesome if you could get me the high speed governor and button number parts numbers. Thx.
  5. pup
    252
    256
    Dec 3, 2011
    n.h.
    Unfortunately my fuel pump code book only covers up to 1988. I can’t find any information on that code
    Hopeaholic Thanks this.
  6. Hopeaholic
    47
    15
    Nov 7, 2018
    No worries. Appreciate you looking! Maybe someone else on here will have a later reference book. Thx.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Try a good pump shop. The reason I mentioned keeping up with all your old parts is from others failures.
    Have seen some folks end up with surging convulsion won't idle rolls like a 2 stroke and other problems. They never could correct the problems they created and had to have the pump rebuilt.
    If you go above more than 250 RPM extra I would keep the button the same as pup said. Some of those engines in industrial units ran up around 2400 RPM. The engine can take it but it is a waste without proper timing. Probably want a piro.
    pup, Hopeaholic and AModelCat Thank this.
  8. Hopeaholic
    47
    15
    Nov 7, 2018
    Agree. Pretty much flying blind on a mechanical without pyro, boost, water and oil temp. Thx.
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    The rpm is as simple as a spring change, if you are wanting an actual performance bump you should pull the pump and send it to a respectable shop.
    Ideally if wanting to raise HP the reliable way to do it is to have injector flow increased rather than just raising rail pressure.
    The timing on a 430 makes it so that the engine will run high exhaust temps if used above 1700rpm, these were timed the way they were to lower the working rpm range to try and bring them in line with mechanical cats of the time.
    Your current timing would be more ideal for working at higher rpm than the timing of the 430hp engine.
    If wanting to get injector and pump work done Premco out of Lampasas, TX builds some of the highest quality injectors around.
  10. MandoDub
    MandoDub Bobtail Member
    34
    122
    Jan 19, 2017
    USA
    That's exactly where I was going to mention he call. Premco. That's who I'm thinking of calling soon. I've got a 350hp N14 1380CPL have only changed the button to a #10 but need to do the proper way w Injectors/Built Pump HT60 Turbo and the add on of PYRO turbo and oil temp gauges.
  11. Fmf1
    Fmf1 Bobtail Member
    Hey bud did you ever get her figured out ?
