Mechanical Question......
Discussion in 'Questions From New Drivers' started by TyWilliams1971, Aug 29, 2013.
  1. TyWilliams1971
    TyWilliams1971 Bobtail Member
    Just bought a 1999 Freightliner, Detroit engine. Was starting up and running fine then suddenly wouldn't start. Replaced the starter but still won't crank over. Anyone have any thoughts or suggestions? Would be greatly appreciated! Thanks!!
  3. biofumes
    biofumes Light Load Member
    202
    96
    Feb 13, 2009
    California
    Batteries, Glow plugs and fuses should be the culprit.
  4. wore out
    wore out Numbered Classic
    16,154
    195,798
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What does the voltage gauge in dash say before and after you hit the start button. I'm assuming you have cleaned all the battery cables and load tested each battery individually. As well as retraced all starter connections to make sure they are hooked correctly
  5. wore out
    16,154
    195,798
    Jun 5, 2013
    Glow plugs on a 60series really driver?
    heyns57, cetanediesel and GasHauler Thank this.
  6. Jaguar115
    Jaguar115 Heavy Load Member
    784
    754
    Apr 4, 2008
    Warsaw, Mo
    Most likely voltage drop between batteries and starter..this old of equipment, corrosion through positive cable.. Or a high resistance to ground through negative cable..
    Does it click or CLUNK when trying to start? Click= low cranking amps from battery..
    Clunk= high resistance to ground/bad negative cable or loose connection.
  7. biofumes
    202
    96
    Feb 13, 2009
    California
    I guess I was being a bit harsh on the guy. This whole CARB situation, let me tell you.....
    Voltage meter should tell you right away...
  8. TyWilliams1971
    when i try to start the truck i turn the key on and wait in till the glow plugs quit then push the start button and everything seems to go low but the head light are strong
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    When you press the start button, that energises the solinoid on the firewall high on the left side check the power to it while someone holds down the button also the ground with be sure there is battery voltage to one side of it, if there is power threw that then it goes to the starter solinoid, check the power to that and the ground wire from the solinoid to the ground post.
    If that all checks out put a volt meter from the negative terminal, on the starter to the battery ground. Then the power to the solinoid to battery Positive.
    If you press the button and nothing clicks, or the solinoid on the firewall gets no power then it is the starter button, or even the starter button is not getting power from the ignition switch.
    Just a thought!
  10. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    If the engine cranks but does not start change the fuel filter and prime the fuel lines.If the engine does not Crank at all then it is electrical.and that could be Ground or fuse or wiring or sensors.also check your ignition switch or fuse.
  11. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    i thought the last glow plugs were on 1693TA cats
