Med card question
Discussion in 'Driver Health' started by Rollin and Trollin, Jun 5, 2019.
  1. Rollin and Trollin
    Rollin and Trollin Bobtail Member
    48
    25
    Jun 7, 2016
    Got my med card updated last week (Texas) and the doc "recommended" I get a sleep study test done because my bmi is over 40%, and therefore only gave me a 3 month card (bmi has been the same the past 4 years, and not once has any other doc even mentioned a sleep study test, and I've been given a 2 year and 1 year card so far til now).
    Question: do I HAVE to take a sleep study test? OR can I either get a new med card asap from a doc who doesn't worry about sleep study tests...or can I get away with losing the 40lbs it'll take to get my bmi under 40% and tell them where to stick their sleep study test?
  3. Chinatown
    Chinatown Road Train Member
    77,734
    184,414
    Aug 28, 2011
    Henderson, NV & Orient
    @Moose1958 may have an answer.
    Seems medical schools have lowered the standards for degrees or some doctors are getting kickbacks if they'll go along with sleep apnea guesses.
    BUMBACLADWAR Thanks this.
  4. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    The CE who did your physical, with the sleep study requirement enters that into a database. You are, for better or worse now tagged.
    BUMBACLADWAR and Chinatown Thank this.
  5. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    You can get a 2nd opinion by another examiner IF you make sure to inform the 2nd examiner of the first exam. Otherwise, you are doctor shopping and the FMCSA will toss any new card you have out. The problem though is most all examiners are picky about messing with another examiners work.
  6. Scooter Jones
    9,551
    19,977
    Apr 19, 2011
    Besides, if you do have severe sleep apnea, wouldn't you want to know?
    I had this very thing happen to me last year in April. I went to my own doctor to get a second opinion.
    He prescribed a home nocturnal oximetry test first. Very simple and non evasive test that measures your blood oxygen saturation during sleep.
    Mine was dropping to the high 70% range at times while sleeping. That was it, the next test was a home sleep test. I tested in the "mild" apnea range and on the mask I went.
    These examiners/doctors are sitting ducks now regarding potential liability and they are going overboard on the side of caution.
    faux_maestro Thanks this.
  7. doc43204
    doc43204 Bobtail Member
    46
    27
    Aug 14, 2018
    Speaking for myself, I had a sleep study done and got the machine.After I used the machine for 2 nights I decided I'd never be without it. I didn't realize how badly I was sleeping until I put that mask on and really slept. After you try it, you really might like it.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    40%? That does not ring true.
    If A person is a certain height and a certain weight the BMI value you want is around 19 for normal anything below say 26 for overweight and nothing over that for Obese more or less. I am running 180 at moment making it edge of normal 19 or so. If I gained 10 I would be overweight. That actually influences a dose of one medicine I recieve against the State Maximum daily MME.
    https://www.vertex42.com/Files/pdfs/2/bmi-chart.pdf
  9. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
  10. Moose1958
    15,296
    33,965
    Dec 17, 2010
    Medical Examiners are NOT under any Liability on this issue because there are NO standards. The FMCSA dropped them after Congress slapped their hands.
    Medical examiners are now doing something more like profiling than anything else. There are also tons of reasons why someone can't get a good night sleep that CPAP (or the mouthguard) won't fix.
    Now if you and anybody else sleep better with CPAP you keep right on using them. However, there are a lot of crooks in this business from crooked carriers to these so-called sleep specialists that are forcing thousands of drivers into unneeded sleep studies so they can make a quick buck.
    I also do not trust most of these studies because I don't know who funded them. I am still yet to see one (CONFIRMED) case of sleep apnea causing a fatality accident.
    I continue to see the list of sleep symptoms growing almost every time I read about it. Every one of these symptoms can be caused by other things. If I don't sleep on the right pillow every night I will wake up with a headache.
    This sleep apnea thing and all the supposed studies behind it are starting to remind me more of global warming. It can be 150 below zero outside and some jackleg climate specialist will swear it is because of global warming.
    With the above diatribe said the question remains, is OSA a problem? Yes, it is. People none drivers included have problems with their tongue blocking their windpipe and they stop breathing. medical science is working on a cure. In fact, I was speaking to one of my doctors at the VA about this during my last appointment. I think the VA is going to start doing these surgical procedures. I find being tied down to a CPAP machine a royal PITA!
    25(2)+2 and x1Heavy Thank this.
  11. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I consider this.
    Truckers have managed to get along for decades since world war one.
    This medical harvesting of people that are a touch "Pudgy" or overly muscle bound etc in the last 15 years has reach what I consider predatory levels. God did not issue CPAP for sleep and ###### if I fall for that hype today.
    If I cannot sleep here, I'll go make it happen one way or another. Sleep for me is to REM and back, the trick is staying there long enough to matter. Not like most people.
