Melton is having a bad day in Knoxville
Discussion in 'Trucking Accidents' started by bryan21384, Jun 4, 2025.
  1. bryan21384
    bryan21384 Road Train Member
    14,887
    32,262
    Sep 18, 2009
    Memphis, TN
    Flying J in Knoxville, load shift. He made too sharp of a turn, out of a parking spot going downhill he was in a bad way. I would have gone up the hill and past that last row in the back and came out the other exit by the Beacon.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,571
    9,101
    Oct 5, 2012
    Earth
    I'd say it's more flimsy trailer than load shift.
    Walk Among Us Thanks this.
  4. D.Tibbitt
    148,263
    That's why u don't jackknife a loaded spread axle... can get away with it when ur empty... dudes got that thing at a full 90 degrees... if u never run a spread axle they will move side to side like that when u turn real sharp, combine that with top heavy load, recipe for disaster.. surprised he didn't pull those trailer tires right off the wheel
  5. bryan21384
    14,887
    32,262
    Sep 18, 2009
    Memphis, TN
    That's exactly what he did. He made a left turn out of his parking spot and another left to head toward the exit on a hill. He needed to have gone the long way and made the right turn to go up the hill........I'm glad you said that because that is the key when backing spread axles too.
  6. Tb0n3
    4,571
    9,101
    Oct 5, 2012
    Earth
    That's why I said it's a flimsy trailer. In my experience the steel frame trailers flex a lot compared to full aluminum. I never run into any issues like that with our reitenouers. Just one of the benefits of aluminum trailers.
  7. bryan21384
    14,887
    32,262
    Sep 18, 2009
    Memphis, TN
    I understand...I still wouldn't have chanced even when I pulled a steel trailer. If I sw even the slightest lean in my mirror, recalculating.............. lol
  8. Tb0n3
    4,571
    9,101
    Oct 5, 2012
    Earth
    It's just a difference in the properties of steel and aluminum. Steel can flex a lot more before it has plastic deformation which is a permanent change. Aluminum has to be thicker and it is much weaker when flexed so it's made to be stiff. All this leads to different performance characteristics of the trailers. The one time I had something heavy on a steel trailer it freaked me out seeing it flex around curves in the highway.
  9. D.Tibbitt
    148,263
    They will all do it if u turn it sharp enough... theres no reason to put a spread axle at that angle, doing nothing but damage
  10. Tb0n3
    4,571
    9,101
    Oct 5, 2012
    Earth
    That depends entirely on where you deliver. We've got lots of really tight places to deliver that are basically just some guys driveway. And by basically I mean exactly some guys driveway.
    One of the easier drive through deliveries.
  11. bryan21384
    14,887
    32,262
    Sep 18, 2009
    Memphis, TN
    Those turns are definitely easy. The Melton driver didn't have nearly much real estate. At least in the pic, the trailer can straighten out some before the next turn.
    D.Tibbitt and broke down plumber Thank this.
