mercedes 460 with ether only
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pichu, Feb 7, 2012.
  1. pichu
    pichu Light Load Member
    103
    19
    Jan 18, 2009
    mexifornia
    hey fellas!! i have a problem i swaped a 460 non egr to a 2009 egr dpf that truck acelerates good and idle good too but when i shut off the key for one minute and i want to start it over...it doesn't want to start up.(only with ether) i try in idle i take out the return line and there is no fuel ?:biggrin_25513:at the same time i take out the hose as well like taking it out from the tank and the motor is still running for 15 minutes it doesn't shut off. so can anyone help me with this problem or how to run the fuel lines? its a freightliner columbia thanks in advance :biggrin_2553:
  3. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    pichu Thanks this.
  4. pichu
    103
    19
    Jan 18, 2009
    mexifornia
    hey dave!!when you say loose prime /is this putting fuel pression to the lines?oh does the system have air (i left the engine running one hour and it sounds good )when you say it could be electronic, what can the problem be?when i got the motor it had one entrance for fuel and return line ,we did not touch anything or do you know if the new engine had a lift pump?or something like that .thank you and i appreciate your time :biggrin_255:
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    it is air in fuel issue. Mercrdes makes good fuel systems and truck keeps running with some cracks in fuel lines, but wont starting well
    pichu Thanks this.
  6. dave26027
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Hi pichu- I would go with Pablo's advice, fuel is leaking out of the system somewhere after it's turned off. Once air gets into the injectors you'll need ether to get it to start. There's a check valve that keeps fuel from draining out when the motor's off, that's a good place to start looking. (I've never actually seen it but it's in there- or should be). A lot of the fuel lines on an MBE are plastic- they get dry or fatigued and crack. When they do, it's hard to find where it's leaking from because the fuel goes all over the place.
    The only other thing that comes to mind is ECM voltage. Your ECM has its' own battery connection-if that's corroded or damaged or that battery's no good and the ECM's not getting enough energy the engine won't start. Once the alternator starts providing energy (starting on ether), it's getting the proper voltage.
    And.. let's see- primary fuel filter leaks can also cause such a problem..
    pichu Thanks this.
  7. pichu
    103
    19
    Jan 18, 2009
    mexifornia
    thanx dave n pablo!!i fix the problem,the problem was the new engine(460 egr dpf),has a extra wire called (crank something) i find it in bunch of wires was desconecting, thanx for you help:biggrin_25514:and now just i show the key n star up!!!!
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    There is check valve and fuel presure limiting valve (4 bar) on driver's side of engine, under plastic cover near the PLD units.
    mercedes really is PLD engine (no pump injectors). Pump units are cam driven (engine is OHV of pushrod design).
    EMC is not so voltage sencitive like Volvo ore DDEC-IV and battery power wires are directly connected to starter power supply so if starter cranks engine no low voltage issues (two red wire positive battery power, two brown - gegative battery power, pin 15 on x2 connector - ignition circuit).
    dave26027 Thanks this.
  9. dave26027
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Good job pichu!!
    You taught us all something, THANKS!
  10. qtip
    qtip Light Load Member
    91
    13
    Jan 2, 2012
    calgary, ab
    On a Mercedes make sure the o ring in the fuel filter is installed correctly as well, thought it was the check valve on one I was driving awhile back. Nope moron changing oil missed an o ring. I know yours is already done but so you know kinda thing
