mercedes and mack e7 engines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tarp 66, Jul 7, 2010.
  1. tarp 66
    tarp 66 Bobtail Member
    8
    lexington oklahoma
    How reliable are the mercedes mbe4000 and the mack e7 425 engines? i am looking at a mack and a freightliner day cab to haul grain from the farm to the elevator. i know about the red top cummins n14 is good but i don,t know about these other engines. the mack is a 2001 and the freightliner is a 2004.
  3. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    The E-7 macks are good engines as long as you dont care about power. Gutless compaired to other engines rated at the same power. Their only 728 cubic inch engines. Dont have nearly as wide of a torque band as the big Cat, Cummins or Detroit for that matter. They last good milage wise and were fairly reliable. They get the job done just not real fast.
    The MBE 4000 on the other hand I've never herd anything good about. Even the mechanics at the local Detroit Diesel/Allison shop hate them. One mechanic told me he wouldn't even use one as a boat anchor because it would probibly only work half the time and his boat would get away.
    Buy the Mack or find a truck with a Cat (15 liter), Cummins (14,or 15 liter) or at least a Detroit series 60. Both the 12.7 and the 14 liter were fairly reliable.
    Buy the way how heavy will you be?
  4. striker
    striker Road Train Member
    6,026
    6,442
    Aug 8, 2009
    Denver, Co
    the Mercedes engines that are in our two freightshakers are junk, fuel leaks, water pumps, belt tensinors, turbos. The make lots of power, but always needing something worked on.
    the Mack Mp8 motors in the new trucks are #### fine motors, there are a few recalls and TSB's for some issues, but otherwise excellent motors. the e7 was an okay motor, nothing to right home about, but properly maintained will last a long time
  5. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    not a thing wrong with pre 04 E7 427 gutless, mine is not does everthing the 460 N-14 and 425 CAT Does they lug right down to 1200 just like a CAT more power at 1400 than the N-14 and run the same speed up the hills and gets the best fuel mileage
  6. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Of the two I'd pick the Mack over the Freightliner. The Macks are sturdy and will take more of a beating (well, the CH and R models anyway, I'm not sure the Vision series is quite as durable). Also I haven't ever heard anything good about that Mercedes motor so I'd have to give the nod to the Mack there too.
  7. Mack427
    323
    93
    Jan 22, 2009
    only diffrence between a vision and a set back CH is the hood and radiator same frame rails, susp., cab ect.
  8. tarp 66
    8
    lexington oklahoma
    I saw a white cat motor in a kenworth and i didn,t know that cat had a white painted motor. Does anyone know anything about what kind of motor and horsepower it has? the owner says it is a 1981 kenworth and it has the white motor and it is the 3406 motor.
  9. shiftin'shell
    shiftin'shell Light Load Member
    102
    164
    Jan 12, 2010
    Dayton Virginia
    Not sure what years they were in but the early 3406's were white. I was told it was before they put the cac on them. But again I'm not sure on this.
  10. Diesel Dave
    8,633
    24,287
    Jan 20, 2010
    Hesperia, Ca.
    It's the 3406A motor. It's the first ones that were built after the 1693TA. The 1693TA were the best. They ran forever BUT, smoke like a train when there were turn up and the fuel mileage wasn't great.
  11. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    i drove a 1693 that was white. And as Dave said, great motor. My only complaint was no engine brake.
    tarp 66 Thanks this.
