Meritor reduction/ power divider diff fluid
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Robkiller, Jun 17, 2023.
  1. Robkiller
    Robkiller Bobtail Member
    17
    Apr 1, 2022
    05 volvo VNL cummins
    So i want to change out my fluid on my diff/power divider. Looks similar to the pic below.
    rt40-145/mt40-14x 40
    Diff. with tandem power divider
    My question is where to add and check the level. I called meritor and they said the normal fill line at the diff cover.
    I was just surprised that the amount of fluid for this would be the same as the rear diff that is only the diff. I was expecting to have a fill/check location higher up on the power divider or a separate hosing of fluid on the power divider to also drain and check.
    Is this correct? Check it same location and fill amount for front and rear diffs with or without the power divider?
  3. Goodysnap
    Goodysnap Road Train Member
    3,751
    9,125
    Jul 12, 2017
    The check plug will be at the same level in the housing front to rear. Should be even with the fill hole cold. The front diff with the power divider will hold more fluid than the rear by about a gallon typically.
  4. Robkiller
    17
    Apr 1, 2022
    Got it done thanks!
