There is a truck I am looking at buying. It has a rockwell transmission, which I do not want. Can I pull it off and install an Eaton Fuller transmission with no issues or is there conversion work to be done?
Meritor/Rockwell swap for Eaton Fuller
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lateralus180, Nov 18, 2016.
They should swap out. may have to change shift lever, yoke, clutch linkage on trans, or driveshaft length. everything else should bolt in place. its not a hard swap.
Reviving this thread. 1998 FLD120. Has a Meritor 10 speed. Want to replace with Eaton Fuller 10 speed. Some say it will bolt right up and others say some parts need swapped. Any new info would be appreciated.
Wonder if I call Eaton and give them the Meritor numbers if they can help?
Also, anybody have a trusted Eaton Fuller supplier? -
the problem is getting someone to get you transferred there.JoeyJunk Thanks this. -
thenewbietruxker and Big Road Skateboard Thank this.
