Metal filings in front diff
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fuelhauler11, Apr 17, 2018.
  1. Fuelhauler11
    Fuelhauler11 Bobtail Member
    Hi, haul fuel here in Canada , 2018 Peterbilt only 250,000 Kms on it , just went in for six month inspection, apparently they have found metal filings in front diff, what would cause this and I would assume warranty yes?
  3. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    yeah probs warranty, and for the front diff it would usually be having the inter axle locked at high speeds or using it when not neccesary, ur probs looking at a rebuild for the diff or power divider
  4. AModelCat
    160,145
    The term "filings" is a very broad term. Is it just some fine metal "fur" on the magnet? Or actual chunks of metal. "Fur" on the magnet is normal, metal chunks are not. You won't have any hope of getting a warranty rebuild if its just considered normal wear by the manufacturer's standards and definitions.
    Heavyd and Roberts450 Thank this.
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    It all depends on the kind and size of the metal filings. Most gear boxes and rear ends will ALWAYS have metal on the magnetic drain plugs when serviced. More so when new/first oil changes as there is lots that wears off during the brake in period. So without seeing what metal came out of the diff we wont have any clue as to whats to much metal or just normal metal.
    mhyn Thanks this.
  6. Fuelhauler11
    Definitely
  7. Fuelhauler11
    Definitely chunks of metal they tell me
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    my guess would be someone locked the power divider while the tires were spinning and shelled out the power divider. i would also guess there going to call it driver abuse no warranty.
    AModelCat Thanks this.
  9. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    If the chunk are big as English peas problem small flakes not probably thrust washer wearing down
  10. I glide 47
    1,426
    1,523
    Jun 3, 2017
    Mt last post and 3 cents are worth a nickel
  11. Heavyd
    Heavyd Road Train Member
    7,780
    6,218
    Feb 4, 2009
    Pictures would be best.
