Method for tandem sliding?
Discussion in 'Questions From New Drivers' started by Trevzx6r, Mar 1, 2012.
  1. Trevzx6r
    Trevzx6r Bobtail Member
    6
    Omaha, NE
    Hey guys,
    I used to generally haul light loads(all under 30k), but now im on a new route where every load is 42k+. At the scales when im over weight on the tandems it seems like i just keep sliding them back until im under 34k.
    Is there a science or method to knowing where to put them? Like does every pin hole mean X amount of weight is being shifted?
    Like just as an example say each pin holes is -100lbs and im 500lbs over. I would slide it 5 holes back.... I know that number is incorrect just using it as an example for what I am asking. Any and all help would be useful, and if you still dont understand I can try and explain better. Thanks.
  3. SmokeyCowboy009
    SmokeyCowboy009 Heavy Load Member
    715
    315
    Mar 4, 2009
    Watertown, WI
    do you have a pressure gauge on your dash? if so wut truck do you drive. if it a shaker your guage will show 60psi for over 40k lbs wgt in the box. if a kw itll be 50psi.
    ok as to the wgt each hole is approx 300lbs. each spot on your 5th wheel is approx 500lbs.
    as a suggestion next time you get loaded set your tandems just behind the 40 mark (front axle). then drive to the scale and see what it shows. if it seems to be heavy on the drives slide them forward a couple holes real slow (pushing the trailer back in reverse). if it heavy on the tail slide em back a couple again real slow (pulling the trailer forward )then scale again. thatll give you a bit of a guide to know where best to set them the next time you have something of the same wgt load.
    Trevzx6r Thanks this.
  4. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    As a general rule each pin hole on trailers is about 10% of the product weight (or at least that is the way our trailers are). so if your load is 43,560 each pinhole would be apprx. 435 lbs.
  5. Scuby
    Scuby Heavy Load Member
    816
    235
    Mar 10, 2007
    Trevzx6r you have the right idea.The thing you have to learn is the settings for the different makes of trlrs. Great Dane,Wabash,and the others have different settings. Most of the trlrs I've pulled have a mark for the bridge formula. What I do is hang a roll of duct tape to where the tandems need to be and adjust that way. The best way to have a trlr loaded is to have the shipper load it like a 48' if they can. This will reduce the chance of being over on the tandems.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,401
    Nov 1, 2010
    Burnsville, MN
    I figure 250-300 pounds per hole.
    Seems to work well with most trailers I haul.
  7. Trevzx6r
    6
    Omaha, NE
    I drive a Cascada, and they are all Wabash. And thanks for all the info. I got a general idea now of how to work it. I guess just exactly knowing will take time.
  8. lonewolf4ad
    7,743
    7,773
    Nov 4, 2008
    Trev, the truck won't be an essential factor. Knowing your trailer model and the type of slide (distance between the pin holes) will be a more important factor. Also, it will be a thing you learn as you get more experience, for now don't be afraid to scale multiple times in order to make sure you're legal. That little yellow piece of paper with the right numbers on it is a valuable piece of mind.
  9. Trevzx6r
    6
    Omaha, NE
    Yea I do alot of split loads and the previous drivers tend to just leave me a scale slip a state over saying its over on the tandems and they are slid all the way forward. lol like uh thanks?
  10. vinsanity
    vinsanity Road Train Member
    1,760
    689
    Nov 23, 2009
    South Florida
    Wabash trailers have more holes tightly spaced. That means less weight transfer per hole. I usually figure around 150 lbs per hole on those.
  11. moderndrifter
    moderndrifter Light Load Member
    208
    86
    Oct 4, 2011
    Colorado, US
    I like that idea - something you can actually see from in the cab. I've just been using chalk.
    mustang970 Thanks this.
