michelin recaps....xda2 custom mold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigdad7, Mar 9, 2013.
  1. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    wells heres for gambling just bought a set of eight michelin recaps with the energy tread pattern through balance beads in em and am running pressure equalizers at 110 .....my last set of virgins ty577s lasted 330000 miles and were at about 5/32 when i pulled em starting to wear a little goofy toward the end
    got a descent price with the balance beads was 2500 out the door will get a check for 450 back once casings xrayed also threw new shocks all the way around a few months back am hoping i get 180,000 miles out of them anyone else have any luck with
  3. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    I also did the same caps on my bridgestones 726 i have mercury balancers but paid 200 per cap on my casings plus 34 per tire to mount. Have a little over 25000 on them. Have passed the 80 mph test with 80k gross for a day. But I did not go over 62 the first week to let them cure. I'm not sorry I got them. They are very good in snow and ice and run just like new tire. I will buy them again.
  4. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    so what custon???????????????
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    110 psi seems a bit high unless you load each axle with dual tires over 24K. 48K on a tandem.
    I run 75 psi in my drives. Read the mfr's load/inflation chart. Uh oh I guess I just started another tire pressure argument.
    RedForeman Thanks this.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,115
    May 19, 2011
    What are you running for drive tires that you can run that low of air pressure?
    volvodriver01 Thanks this.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    WHAT? 75 psi ? you crazy semi? oh sorry got that backwards.:biggrin_2559: 105 p.s.i. should be the norm. 75 does seem too low, but if that is was is recommended...
  8. Semi Crazy
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    11R24.5 load range G
    I could run 70 psi if I wanted.
    http://www.bfgoodrichtrucktires.com/assets/pdf/BFG_Data_Book_Jun2006.pdf
    Page 13 is the load/inflation table
    4660 lbs max load per tire with duals @ 70psi x 4 tires per axle = 18640 max load per axle. I'm over/illegal at 17K on each drive axle so why air it up for weight I'm never going to carry?
    Steers I run 80-85 psi
    Spread on trailer has 275/80 22.5 and those I put at 100 psi.
    Been doing these pressures for about 10 years and driving slower and I get the best wear I ever got.
    Used to always get irregular wear with hard tires and hi-speed driving back when fuel was $1/gal.
  9. Oscar the KW
    12,246
    28,115
    May 19, 2011
    I would think running that low of psi would wear the outsides of the tires out, and I have always heard you want more psi for better fuel mileage.
  10. terryt
    736
    777
    Apr 27, 2009
    tire wear goes up at the low of air pressure plus running hotter is not good for caps. Would never run a tire under 105 psi. But it your truck and you are free to do as you please.
  11. black ultra
    black ultra Light Load Member
    62
    13
    Feb 16, 2012
    conroe tx
    I always run my tires at what the tire mfg. says to run them at! In the great state of Texas a tire that's over,or under 10% psi. wise will get you a ticket!!
