Can anyone give me the definitive meaning behind a Class B Road with a weight restriction of 18000 Single 26000 Tandem? I drive a straight truck that has been scaled at just over 18000 lbs with no load on it. Do these signs, which are pretty much all over the place in Michigan, mean 18000 GVWR or 18000 LBS is allowed on the rear axle. Any help is appreciated. Thx.
Michigan Weight Restriction Question
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by monofrey, May 6, 2018.
To clarify on your straight truck that means no more than 18000 on your steer axle and 26000 on your drives if its a tandem. If its a single axle than 18000 on the drive too then. Pretty common weight limit in Michigan especially in the spring.
Frost laws are now off in almost all of lower Michigan. When they are on you need to reduce axle weight by 35 percent and speed is reduced to 35 mph. The speed is what a lot of places watch the most on the west side.
To be honest l had a pretty good grasp on michigan weight laws in the urban areas but when they start calling them b roads l'm a little lost too. Like you said if its posted with an axle weight rating you should be good to go. Even if its reduced by 35% for spring thaw you should be good to me. Not like dot or cops never do a cash grab and hope you just pay it though
monofrey Thanks this.
