Microwaves?
Discussion in 'Maverick' started by CaptainX3, Feb 3, 2013.
  1. CaptainX3
    CaptainX3 Road Train Member
    1,408
    1,057
    Nov 10, 2011
    Fort Worth, TX
    Hey guys,
    I wanted to ask the other drivers out there if they are using microwaves in their trucks, and how powerful they are. I spent a decent amount of money recently on a Whirlpool compact microwave that actually fits into the cabinet in the truck, but apparently there isn't enough power to run it. It's a 750 watt microwave, and even though it turns on, the magnetron won't kick on.
    After I found out that our trucks inverters are only 1400 watts, I broke down and bought a 700 watt microwave from Wal-Mart and put it in here. However, it just BARELY runs, if I unplug everything else in the truck before I cook something. If I don't unplug everything, it trips the breaker in the inverter immediately, and I have to go reset it in the sidebox there.
    Is anyone else having this issue? 2 drivers I spoke to swear that they run 900 watt microwaves in their trucks, but I don't see how... mine can barely run 700. Can anyone confirm that this is normal, or am I looking at an electrical problem in the truck?
  3. Danfromwindsor
    Danfromwindsor Road Train Member
    1,632
    614
    Mar 26, 2010
    I know Jim the Hut runs a microwave. I think his is a small 700 watter also. I run one but Im in a different truck and have a 1000 watt inverter. Ive never had any problems running my 700 watt walmart cheapo on my 1000 watt inverter. Jim had an issue a while back with his microwave but that was after it had bounced around in his truck for sometime. I think however he got the issue resolved and its working again. You might message him and see what kind of issue he had and what he did to fix it.
  4. CaptainX3
    1,408
    1,057
    Nov 10, 2011
    Fort Worth, TX
    Hmm, maybe my truck does have an electrical issue then... it definitely wouldn't be the first. This truck has been a nightmare in regards to breakdowns ever since I got it. I should've seen it coming the moment I got in it and saw "21" on the odometer lol.
  5. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Without knowing the model number if the microwave it is hard to say what the issue but a 1400 watt inverter should have no issues with a 750 watt microwave. How is your inverter wired? I think your inverter is not putting out 1400 watts
  6. CaptainX3
    1,408
    1,057
    Nov 10, 2011
    Fort Worth, TX
    I have no idea, it's the one installed in the truck, I suppose at the factory (the inverter I mean). It's somewhere in the sidebox. As far as I know, we can't install any other inverters. Someone told me that for a microwave, it requires double its wattage for a split second when it powers on, and that's why 750 watts wouldn't work on a 1400 watt inverter. I wasn't sure if that was true, but once I tried my 700 watter from Wal-Mart, and it BARELY runs (and I mean barely, the lights dim when it runs lol), I figured there was some truth to it.
  7. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    I never run my microwave without the truck idling. Too much draw and I have a 2500W inverter in my truck.
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The inverter shouldn't be mounted no further than 4 feet from your batteries. Any more distance and you experience voltage drops and wires heating from the excess resistance. It's okay to use a 6'-10' foot extension cord coming out but the power feed needs to be short.
    Also check your battery connections. A poor or corroded connection can be the culprit.
    You should know where it's at if you are plugging into it?
    Cranky Yankee Thanks this.
  9. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    I run mine nearly every day. It's the little Wal Mart one. But have 3000 watt inverter. Check yours. It may be `1400 peak or just for momentary use at that level. Also make sure all the wiring is good and tight and large enough. Had one of our trucks the other day wouldn't start. Got into box and under inverter wires was corroded and nut was split. He is supposed to check and tighten nuts once a week. LOL
  10. CaptainX3
    1,408
    1,057
    Nov 10, 2011
    Fort Worth, TX
    The inverter was installed into the truck at the factory. The plugs I use are installed into the wall of the cab. There are two below the bunk, and two more on the back wall of the cabinet where you would normally put a TV. There are 4 more outlets in the sidebox itself, although I have no idea what the heck I would use those for. I didn't install it and know nothing about it.
  11. Quickfarms
    898
    236
    May 29, 2012
    Los Angeles, Ca
    You need to locate the inverter and make sure that the cooling fins and fan are clean and working in addition to checking the contacts.
    I have had several inverters fail over the years. The inverters would work fine on a small load but would not produce full capacity.
