Mid 128 sid 412 fmi 0.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shashamane, Jun 22, 2018.
  1. Shashamane
    Shashamane Bobtail Member
    19
    6
    Feb 6, 2017
    Good afternoon fellows,i have a big problem here.2005 vnl 670 isx cummings.when loaded,am geting this black smoke.i changed egr valve last week and looks like i gad a fake mechanic.am still having the same problems i had before changing the egr valve.i took my truck to volvo dealers and they are giving me a headache.3 hours and they cant find the #### problem.they are telling me it might be the turbo charger valve stuck open and i dont wonna here that it might.any help guys i will appreciate.
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Any other codes besude that one?
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    • Fouled EGR cooler
    • Intake manifold, charge air cooler, or EGR leaks
    • Failed EGR differential pressure tubes
    • Failed EGR valve
    • Stuck open turbocharger control valve
    • EGR differential pressure sensor reading low
    • EGR valve position sensor reading low
    • High exhaust temperatures
    • Stuck closed variable geometry
    You need a shop/dealer to figure out the problem. Not much else can be done without having the Insight tech program..
  5. Shashamane
    19
    6
    Feb 6, 2017
    No other code .it only appearing with lots of smoke while loaded
  6. Shashamane
    19
    6
    Feb 6, 2017
    Hope this will save my fellow owner operator's some day.that demn thing is the problem.exhaust gas recirculation mixer ejector is leaking inthe connection.collision inside where the o ring seal..thanks alot guys
  7. Shashamane
    19
    6
    Feb 6, 2017
    This thing here.air was leaking from this demn thing
