Mid 136 sid 7 FMI 14
Discussion in 'Volvo Forum' started by kotozcosmin, Feb 27, 2018.
  1. kotozcosmin
    kotozcosmin Bobtail Member
    Hello everybody.
    in very cold mornings I get the error:
    mid 136 sid 7 FMI 14
    When i get this error My i-shift gearbox is working only in manuel, after 30 minutes-1 hours when temperatur is Up,start to work normal.
    I have a Volvo fh12,460 HP from 2011 whit pusher.
    What can be the problem?
    Thank you very much.
    I wish Good Luck för everyone.
  3. kotozcosmin
    Here is My pictures whit problem
  4. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
  5. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    @nasriza
    He is the Volvo guru, maybe he will chime in soon
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    it just shows as a modulator valve normal over the road volvo should not make a difference in shifting, so driver side modulator i would buy a new one and plug it in to see if the code shuts off if it doesn't than need to trace the wiring from there to the abs ecu. pretty simple.
  7. rabesouci
    rabesouci Bobtail Member
    hello, I have the same problem on my volvo fh12. Do you remember the solution? Thank you. Here is my diagnostic default
