MIFI best place to put it
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Big Rigg, Oct 1, 2011.
  1. Big Rigg
    Big Rigg Medium Load Member
    360
    317
    Jun 14, 2011
    Corona, CA
    I just got a mifi from verizon and it works good. I got the 3g one because the 3g has more coverage in the areas i go to. Being a rookie and low man on the totem pole I get sent to all the towns out in the boonies for loads. I still get a signal on the mifi but is weak so my question is this. Where is the best place in the truck to place the mifi to optimize the signal? I'm assuming that all the metal and other electronics in the truck may interfer with the signal.
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Does it have a connector for an external antenna? If so, you might contact Wilson for a signal booster..
    Mark
  4. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    It doesn't work like that as far as I know, they're designed for being indoors. Also 3G is going to be slow in a lot of remote places regardless.
  5. AZS
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    It can't go outside..unless he wants to be replacing it very quickly.
  6. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Check with Wilson anyways.. I think they make a wireless booster now. The booster would connect to an external antenna on your mirror. I ran one with my aircard and got a 2-3db signal increase. BTW every 3db is a double of power.
    http://www.wilsonelectronics.com/ProductDetails.aspx?Product=42&title=MobilePro%c2%ae+(801240)&Category=6
    http://www.wilsonamplifierstore.com/catalogsearch/result/?q=801240
    Mark
    AZS Thanks this.
  7. sixpackbill
    sixpackbill Light Load Member
    114
    29
    Oct 6, 2010
    hamilton on.
  8. Pegasus
    Pegasus Medium Load Member
    366
    106
    Aug 27, 2011
    in the universe
    MiFi is a line of compact wireless routers produced by Novatel Wireless that act as mobile Wi-Fi hotspots. MiFi stands for 'My Wi-Fi'. The MiFi can be connected to a mobile phone (cellular) carrier and provide internet access for up to 5 devices. The MiFi works at a distance up to 10m or 30 ft and will provide internet or network access to any WiFi enabled peripheral device.
  9. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Also to add, most are encrypted. So the truck next to you cannot hop onto your MiFi.
    Thanks,
    Mark
  10. AZS
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    Interesting didn't know about that, might have to look into it. Thanks.
  11. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    I've got mine (ATT) velcro'd to the front side of my cabinet above the passenger seat. Unless I'm in a really bad reception area moving it doesn't help. Plus I always know where it is.
