MIG weld versus Arc weld on antique truck?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Aug 18, 2024.
  1. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    Just curious of you guys that do both types of welding what you think.
    I have an antique truck that I am going to extend the frame on. The truck has the same heavy duty frame like a tri-axle truck or truck tractor.
    I'm sure someone is curious, it's a 1968 n950 Ford truck with a 671 Detroit.
    My MIG welder will weld up to 1/2 inch steel. I think most of the frames I've dealt with are 5/16 or 3/8.
    My own personal feeling is that even though Mig can weld up to a half inch, I personally think that the arc weld just penetrates better and is better for very heavy things like truck frames.
    With that being said, I'm not sure if the older frames were heat treated, and I will use A36 for the inner rail. The outer rail I have frame rails from another truck that was from the late seventies that will fit, but they need to be welded onto the existing outer rails where they are still good.
    I've always intended on buying an arc welder, just haven't had a reason to actually buy one yet. It's always better to not spend more money, but it's very probable I will be doing more framework in the future.
    I also will also be fabricating pintle hook plates, dump bed repair, probably making tailgates, floors Etc.
    I think Mig is just incredibly useful and versatile, but like I said I think when you get into heavy metals the arc will penetrate better.
    For you guys that have both and have used both, what do you think?
  3. Goodysnap
    Goodysnap Road Train Member
    3,717
    9,024
    Jul 12, 2017
    I personally wouldn’t buy another welder if I already had a MIG capable of completing the task. Clean it up good, taper it back and lay it in.
    beastr123, Vampire, Sons Hero and 3 others Thank this.
  4. AModelCat
    159,076
    Last shop I worked at had a fabrication department. We were welding up to 1-1/2" plates together with a MIG and no issues. Get the proper wire and go for it IMO.
    beastr123, Puppage, Vampire and 3 others Thank this.
  5. SmallPackage
    5,458
    17,352
    Dec 20, 2019
    Marion Texas
    I got welding cert in high school and got my ojt when i worked under the table cash jobs for a drilling company my dad worked for while still in high school. Just like back then, Nowadays All the old timers I know are using the old engine driving Lincolns to stick weld everything. But they are old school oilfield and pipe fitter trained. Very hard to get them to adapt to mig. So they let me do the “light weight” stuff as they call it. I have welded frames with mig many times and lots of structural type stuff with mig with great results. The key to mig on thick stuff is the highest heat possible and multiple passes. I don’t use gas because of the cost and pain to get bottles and the amount of welding I do but the gas does make for nicer looking beads and thats really the only benefit.
    The nice thing about the mig in our case with the old trucks is they are great for sheetmetal work and the rusty steel cabs.
    The older frames are much harder steel then the newer ones. They have less flexibility which is bad for drilling but good for welding. You should have no problems when following the standard frame repair, cut- off, stretch procedure when using mig. Just use more passes. You will see what I mean when you get into it.
    Sons Hero, Oxbow, Dino soar and 2 others Thank this.
  6. AModelCat
    159,076
    Gas with fluxcore is amazing. Most common wire we burnt was 1/16" and that flux would just flake off with the slightest breeze.
    mile marker 27, W923, Oxbow and 2 others Thank this.
  7. Big Road Skateboard
    6,184
    33,971
    May 2, 2021
    I've got both, and would use stick personally since I can.
    If I only had mig I wouldn't think twice. I just have done more stick.
  8. Opus
    121,001
  9. Dino soar
    4,791
    26,878
    Dec 8, 2017
    I welded plenty of stuff over the years with my MIG welder.
    I think the pintle hitch on my dump truck was close to half inch. Never ever ever in all those years did I ever have any problem whatsoever.
    In fact the top was welded to the dump bed and I had to cut that off to get the bed off. So it was only held by three sides. Then I had to pull my trailer out and it was stuck.
    The truck is basically a junk truck I'm going to pull the engine out of now, so I took a running start maybe six or seven times bang! And I mean that trailer was loaded heavy and I kept banging it until I pulled that son of a gun out. It was the only option I had at the time.
    Zero problems with the weld.
    I did have an old school guy tell me to run the torch over the area I'm going to weld. He said it doesn't have to be hot like you're trying to get the steel hot to cut it or anything like that, he said just run the torch over it just a little bit so there's a little bit of heat and the steel is not just cold. He said that would give you better penetration.
    True or not that's what he told me. That guy had been at it for many many decades.
    Hey that's great if I don't have to buy a stick welder, but you guys really don't think that the stick penetrates deeper than Mig if you put them side by side?
    Feedman Thanks this.
  10. Cattleman84
    Cattleman84 Road Train Member
    9,921
    70,789
    Nov 1, 2017
    The Sticks, Idaho
    If you are a compitent welder MIG will work just fine... I have stretched a few frames and added butt-plates with pintle hitches for pulling full size tank trailers. Used mig for all of them and they are still going strong after nearly 10 years.
    Here are a few pics of one I built in 2015... Pics were taken in 2022. Everything from the end of the frame rail back/down,as well as the tail light tubes, is my work. The 3/4" flanged phos and oil frame bolts were used just as a little extra assurance... But as you can see they were not really necessary.
  11. Lane=addict
    Lane=addict Light Load Member
    74
    63
    Aug 12, 2024
    Earth
    My 2 cents all welders work. But arc does not care how fast the wind is blowing, or what the weather is. :tongue7:
    mile marker 27, W923, Luwi67 and 5 others Thank this.
